RaceCapture App User's Guide
- OS X: port scheduled
- Android: Beta available, contact us a [email protected] for access
- iOS: port scheduled
Downloads
Discussion Forums
In the spirit of sharing and collaboration, please post all of your questions / testing results / feedback in the community forums.
RaceCapture V2 App/Firmware Discussion Forum
Check out some kickass features:
Capable of running on Windows and Android, the new RaceCapture app will ultimately combine RaceAnalyzer and the current Mobile app into a unified configuration, dashboard and analysis solution.
The latest race track configurations can be automatically downloaded and synchronized from http://www.race-capture.com via the application. If your track is not in the list, email us at [email protected] and we will work to get it added.
Multi-Sector Timing
Separate Start/Finish Lines
To enable auto-x/rally/hillclimb scenarios we've enabled the ability to define a separate start and finish line.
Predictive Lap Timing
CAN bus expansion
OBD2 support
Virtual Channels
Lua Scripting
- Use the print() and println() to print out log messages which will show up in the scripting view. Great for debugging.
- If a wayward script somehow crashes the firmware, the RCP watchdog will fire and start up RCP in safe mode, illuminating the red LED and bypassing script execution. Then, you'll have a chance to make fixes.
- Functions have been streamlined and normalized for consistency. Additional Lua functions have been added to support virtual channels, OBDII and CAN bus messaging.
Improved log timing accuracy
Upcoming Features
Dashboard
- Multi-gauge dashboard view
Analysis
- Line charts showing channels over distance, with the ability to combine multiple channels into a single chart
- GPS plots showing the line taken in reference to the center line of the track map
- Sector times for each part of the track
Firmware
- Windows: Check under Device Manager for a RaceCapture/Pro device under the Ports section.
- Linux: When plugged in, a CDC-ACM device should show up. Check it by issuing the dmesg command; typically it will be /dev/ttyACM0
Application
Install the RaceCapture app after downloading the setup package from the downloads section
Running
Editing Configuration
Auto track detection
GPS Configuration
Analog Channels
- Raw value
- Simple linear scaling
- Interpolated map
- Note Channel #8 is fixed as a battery input channel and should not be changed.
Pulse/RPM Sensors
- Channel Operation Mode: RPM, frequency, or pulse period
- Clock divider: This specifies the operating range for measuring the pulse. This is typically left at 128.
- Pulse Per Revolution / Teeth Per Wheel: This specifies the number of pulses representing a complete revolution of the wheel.
- For RPM mode This value is typically set based on the number of cylinders and the number of coil packs used on the engine
Digital In/Out
- Mode: Set the channel to input for reading digital on/off sensors, or output to use the channel in output mode to control a device.
Accelerometer/Gyro
Pulse/Analog Out
- Output Mode Select either Frequency / Pulse Width Modulated (PWM) mode or analog output mode. Note, to enable analog mode you also need to flip the hardware dip switch on the RaceCapture/Pro main board.
- Logging Mode Select either logging the frequency or the analog output voltage.
- Startup Duty Cycle The default duty cycle when the system starts up.
- Startup Period The default startup value for the pulse period. A larger number means individual pulses are spread further apart.
CAN Bus
OBD II
Bluetooth
You can enable Bluetooth via the Wireless settings. After enabling and saving the configuration to RaceCapture/Pro, following these steps:
- Install the Race Capture app on your Android device from the Google Play Store
- Turn on Bluetooth on your tablet and pair with RaceCapture/Pro, password is 1234
- Open the RaceCapture app, tap the screen until the RaceCapture logo show up at the top.
- Tap the Bluetooth icon at the top right
- Select RaceCapture/Pro
- After a few seconds you should see a 'Connected to RaceCapture/Pro' message and data will be transmitting to your tablet.
- Swipe to the digital dash screen and you should see values changing, pick up your RaceCapture/Pro and move it around, you should see even more sensors changing!
Telemetry
For detailed setup instructions read our Telemetry Quickstart
