RaceCapturePro Lua Scripting Examples
API Reference
if getGpsSpeed() > 10 then
startLogging()
else
stopLogging()
setTickRate(30) function onTick() local arm = getGpio(0) local g = getAccel(1) if arm == 0 then stopLogging() end if arm == 1 and g < 0.1 then startLogging() end end
setGpio(0, 1)
else
setGpio(0, 0)
or
- Using PWM/Analog output
function onTick() local p = 0 if getAnalog(0) < 10 then p = 100 end setPWMDutyCycle(0,p) end
- Using GPIO in output mode
Given:
- RPM sensor on timer input 0
Given:
- CAN1 channel is used
t = readAnalog(0)
msg = {t}
txCAN(0, 1234, 0, msg)
Given:
- creates a channel named "RPM" that logs at 10Hz
- Note, the channel "RPM" needs to exist in RaceCapture/Pro's known list of channels
- Sets tick rate to 10Hz
rpmId = addChannel("RPM", 10)
id, ext, data = rxCAN(0, 100)
setChannel(rpmId, data[1])
Gear Calculation
local 1stGear = 3.5
local 2ndGear = 2.7
local 3rdGear = 2.0
local 4thGear = 1.4
local 5thGear = 0.9
local FinalDrive = 3.21
--diameter in inches
local TireDia = 25.0
local gearErr = 0.1
local rpmSpeedRatio = 0
local speed = getGpsSpeed()
local rpm = getTimerRpm(0)
gearId = addChannel("Gear",5)
if speed > 10 then
if ((1stGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 1 end
if ((2ndGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 2 end
if ((3rdGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 3 end
if ((4thGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 4 end
if ((5thGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 5 end
else gearPos = 0 end
