RaceCapturePro Downloads
Revision as of 22:50, 24 March 2015 by Brentp (talk | contribs) (→Windows)
RaceCapture App
  • Use the RaceCapture App to configure and visualize data from your RaceCapture/Pro device.
  • For MK1 and MK2 versions of RaceCapture/Pro
    • MK1 users: ensure you have updated to the latest V2 firmware.
Windows
Requires: Windows 7+; 2GB RAM; OpenGL 2.0 graphics support
RaceCapture App v1.2.4
Note: The app will fail to launch if OpenGL 2.0 graphics are not supported. If this happens try updating your graphics driver.
Previous Versions
Mac OS X
RaceCapture App v1.2.4 Beta
Requires OSX 10.6+
Unzip the file and copy the RaceCapture app to your Applications directory.
This is a beta it may crash or have unexpected behavior. Please file bugs on our forums here http://www.autosportlabs.org/viewforum.php?f=33
Linux
Packages coming soon!
Mobile App
USB Driver
  • OS X: No driver needed
  • Linux: No driver needed
RaceCapture/Pro MK2
Firmware
Previous Versions
How To Update Firmware
RaceCapture/Pro MK1
Firmware
The V2.x.x firmware for MK1 is considered 'stable beta' - We feel it's much better quality than the previous 1.2.x firmware and RaceAnalyzer combination, but since it is the first V2 firmware and app release for MK1, we are officially calling it Beta. Please visit the Discussion / support forum for help.
Previous Versions
MK1 Bootloader Releases
Firmware update utility
