RaceCapturePro Lua Scripting Examples
API Reference
Automatic logging control
- System battery voltage is tied to the last Analog channel (7)
function onTick() if getAnalog(7) > 13 then startLogging() else stopLogging() end end
setTickRate(30) function onTick() local arm = getGpio(0) local g = getAccel(1) if arm == 0 then stopLogging() end if arm == 1 and g < 0.1 then startLogging() end end
Alerts/Notifications
Create an over-rev marker
overRevId = addChannel("OverRev", 10) setTickRate(10) function onTick() local rpm = getTimerRpm(0) local overRev = 0 if rpm > 8000 then overRev = 1 end setChannel(overRevId, overRev) end
or
- Using PWM/Analog output
- Using GPIO in output mode
Given:
- RPM sensor on timer input 0
CAN bus scripts
Given:
- CAN1 channel is used
function onTick() t = readAnalog(0) msg = {t} txCAN(0, 1234, 0, msg) end
Given:
- Sets tick rate to 10Hz
Gear Calculation
--Developed by Luther Lloyd III 8/22/14 for use by Autosport Labs Community --Copy this text into the scripting window of Race Analyzer --Edit the gear ratios to mathc your car --Add another gear row if needed for 6th gear or delete extraneous ones --below values are constants for the vehicle local 1stGear = 3.5 local 2ndGear = 2.7 local 3rdGear = 2.0 local 4thGear = 1.4 local 5thGear = 0.9 local FinalDrive = 3.21 --diameter in inches local TireDia = 25.0 --allowable error of gear ratio to allow for measurement variation local gearErr = 0.1 local rpmSpeedRatio = 0 --initialized to 0 so if it doesn't work you know local gearPos = 0 --this is the gear channel variable function onTick() --updates gear position every second by default --assumes Pulse Input channel one is for the RPM signal and speed in MPH local speed = getGpsSpeed() local rpm = getTimerRpm(0) --this part only works for firmware version 2.0 per the RCP page gearId = addChannel("Gear",5) if speed > 10 then --makes sure your rolling so as not to divide by 0 rpmSpeedRatio = (rpm/speed)/(FinalDrive*1056/(TireDia*3.14159)) if ((1stGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 1 end if ((2ndGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 2 end if ((3rdGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 3 end if ((4thGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 4 end if ((5thGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 5 end else gearPos = 0 end setChannel(gearId, gearPos) --outputs to virtual channel end
