RaceCapturePro Downloads
Revision as of 15:41, 2 November 2015 by Brentp (talk | contribs) (→Android: removed beta instructions)
RaceCapture App
  • Use the RaceCapture App to configure and visualize data from your RaceCapture/Pro device.
    • MK1 users: ensure you have updated to the latest V2 firmware.
Windows
RaceCapture app downloads
Requirements: Windows 7+; 2GB RAM; OpenGL 2.0 graphics support
  • The app will fail to launch if OpenGL 2.0 graphics are not supported. If this happens try updating your graphics driver
Windows USB Driver
Mac OS X
Requirements: OSX 10.6+
Unzip the file and copy the RaceCapture app to your Applications directory.
Android
Android:
Google Play Store Download Amazon App Store Download
iOS
IOS support coming in a future release.
Linux
Packages forthcoming; meanwhile run from source from the github repository
Firmware
RaceCapture/Pro MK2
RaceCapture Firmware Downloads
Installation instructions can be found in the zip archive.
Additional information
RaceCapture/Pro MK1
How To Update Firmware
MK1 Bootloader Releases
Firmware update utility
