RacecapturePro MK3 hardware install
Mounting Orientation
Alternative Mounting
  • Example:
    • Upside down
    • Vertical / on edge
Main Connector
Power
Connection Color
12v Red
Ground Black
Frequency / RPM sensor inputs
Blue Frequency / RPM input 1
Voltage Reference
Yellow +5v reference
Analog Sensor Inputs
White Analog Input 1
Gray GPIO 1
Gray / White Stripe GPIO 2
Gray / Blue Stripe GPIO 3
Auxiliary Serial Input
CAN Bus
Orange CAN 1 Low
Plug Connector Type
  • Compatible Pins: Molex 46018-1541 or 46018-1541
Other connector sources
Cellular Telemetry
Antenna Placement Guide
Cellular antenna
Antenna separation
RJ45 CAN + Power connection
OBDII CAN cable
Custom Cable
+12v Brown
Ground Orange/White
CAN 1 High Orange
CAN 1 Low Green/White
CAN 2 High Blue
CAN 2 Low Blue/White
Analog Sensor inputs
Analog channel specifications
Voltage Range 0-5v
ADC precision 12 bit SAR
Connecting Sensors
Voltage Range 0-12v
Signal input quality
Special note about RPM inputs
If your only source for RPM is the trigger wire driving the ignition coil primary winding, then you will need the CoilX module to buffer / filter the noisy, high-voltage component.
Connecting Sensors
See our RaceCapturePro_RPM RPM connection guide for more information connecting and calibrating these frequency / RPM channels.
GPIO
GPIO channel specifications
Input Mode
Important Note: when sensing large inductive loads, such as sensing brake light state or sensing motor state, connect a 10K 1/4 watt resistor in-line with the GPIO input to protect RaceCapture/Pro from a very large inductive spike.
Output Mode
Output Behaviour
GPIO Connections
Controlling GPIO Ports
Communications
CAN Channels 1 / 2
CAN channel specifications
CAN channels 2
CAN Filters 14 per channel
Auxiliary Serial
One Auxiliary RS232 compatible serial port is available on the main connector. You can use this to communicate with external devices that uses RS232 serial for communications.
