RaceCapture DashWare Guide
Record and save data on RCP
- Open the log file in Excel, go to Data > Convert Text to Columns > Use comma for the seperator
To add the RaceCapturePro.xml data profile to your system in Dashware go to Project --> Data File(s) --> Add --> Edit Profiles... --> Add New Data Profile... --> and click on Open Data Profiles Directory. This should open the C:\Users\YourUsernameHere\Documents\DashWare\DataProfiles directory. Copy the RaceCapturePro.xml into that directory, then hit the Refresh button on the New Data Profile window, then hit cancel. You should now be able to select the RaceCapturePro data profile. If not, close the application and open it back up. It is a good idea to take a look at the mappings to see what data is mapped to which Dashware inputs. Note that PredTime is mapped to SCUBA->Dive Time Remaining (Mins). I have mapped Brake in RCP to Brake Position in Dashware. If you are using Brake for Brake Pressure, you will have to change that mapping in Dashware.
If you need more info or would like to create your own Dashware Data Profile, please see Step 3 of Rowan Hicks excellent guide here. https://www.rowanhick.com/2016/01/07/racecapture-pro-dashware-win
Fix your video file if needed
