RaceCapture-Track
Revision as of 17:31, 6 April 2019 by Brentp (talk | contribs) (→‎More)
Start it up
Plug it in
Download the app
Navigating dashboard screens
Setup Mode
Explanation of buttons
Enabling Telemetry
Notes about Android devices
Logs
Analysis Mode
Navigating data
Selecting time vs distance
RaceRender
Applying Decals
Updating Firmware
Firmware update is performed using a Windows or OSX machine via the USB interface. Be sure you have the RaceCapture app installed on your computer before proceeding.
  • Download the latest firmware for your system, making note of the hardware version. Ensure it is RaceCapture/Track MK1
  • Unzip this firmware archive to a location on your computer.
  • Connect your RaceCapture system to your Windows or OSX computer using the included USB cable.
  • Navigate to the Setup view
  • Browse to the unzipped firmware from the first step. Select the file ending with ".ihex" - example RaceCapture_Track_2.15.1.ihex and press Open
  • Restore your saved configuration by pressing the Open button, selecting your saved configuration, and then Write it to your RaceCapture system.
More
Alternative ways to power
USB
Custom Cable
+12v Brown
Ground Orange/White
CAN 1 High Orange
CAN 1 Low Green/White
Steps to recover:
  • Connect RaceCapture via USB
