Add TPMS Data
You can cheaply and easily add Tire Pressure Monitor System data to your Race Capture Pro, Race Capture Track or Podium Connect devices with the $225 TrailBrake.com CAN enabled TPMS.
The system is available in external screw on sensors and internal rim mounted sensors. Both are available for $225. Both have channels for pressure, temperature, volts (to monitor battery life), and leak alarm.
Race Capture Pro MK3
For the Race Capture Pro MK3, you can wire CAN High and CAN Low to either CAN 1 or CAN 2 on the Molex connector. CAN 1 is recommended as that is what the provided Preset defaults to. If you wire it to CAN bus 2, you will have to go into each TPMS channel and change it from CAN Bus 1 to CAN Bus 2.
RaceCapturePro MK3 Rear Diagram.png RaceCapture Pro MK3 Molex CAN pinout.png
Podium Connect
For Podium Connect, you can add wires to CAN2 on the Molex connector using Molex 39-00-0039 pins. Again, after applying the Preset, you will have to go in and change the CAN Bus 1 to CAN Bus 2 for each TPMS channel.
Race Capture Pro MK2 and Race Capture Track MK2
You can also create a custom RJ45 cable and put the TPMS on CAN 1 by soldering the Green TPMS CAN High wire to the Orange wire for Pin2 on the ethernet cable and the White TPMS CAN Low wire to the Pin3 Green/White wire of the ethernet cable. To wire it to CAN 2, use Blue and Blue/White wires of the ethernet cable respectively. Please see this link for more detailed info. This would also allow the TPMS system to work Race Capture Track and older Race Capture Pro MK2 systems.
RJ45 Splitter
Note that the baud rate for this TPMS system is 1M. It can be on the same CAN channel as AIM systems since they both have 1M baud rate. Most OBDII systems have a Baud rate of 500k, so the TPMS would not be able to share the same CAN channel as those systems. You would need to use a RJ45 CAN Crossover Cable in that case.
Configuring Settings in Race Capture App
Enable CAN
Now that you have the system wired up, go into the Race Capture App, turn on CAN Bus and make sure the baud rate is set to 1M for the CAN Channel you wired the TPMS to.
Install Preset Channels
Now go to CAN Mapping, click on Presets. Click Update at bottom, then Select Tyre TPMS.
If you wired the TPMS to CAN Bus 2, you will need to edit each channel and change the CAN Bus from CAN Bus 1 to CAN Bus 2.
Write config and verify
Notes
Note: The external batteries should be replaced when they fall below 2.0 volts. You can set alarms/alerts in Race Capture App to notify you when the voltage starts to get too low.
Note: The pressure resolution is about 0.75PSI, therefore you probably only need to see a precision of 0 (ie, no decimal places).
Note: The temperature on my system seemed to read about 4* high and was not consistent from wheel to wheel. Everything else seemed pretty accurate.
