RaceCapture DashWare Guide
Record and save data on RCP
- Open the log file in Excel, go to Data > Convert Text to Columns > Use comma for the separator
You can clean up the headings and remove any rows without latitude and longitude by uploading your log file here. You will still need to create a new column and get seconds as mentioned above in step 4.
If you need more info or would like to create your own Dashware Data Profile, please see Step 3 of Rowan Hicks excellent guide here. https://www.rowanhick.com/2016/01/07/racecapture-pro-dashware-win
Fix your video input file if needed
