RaceCapturePro Lua Scripting Examples
API Reference
Complete API Reference
OBDII tricks
Complete OBDII PID reference
Clear current trouble codes
setTickRate(1)
count = 0
 checkClearCodes()
function checkClearCodes()
  if count % 10 == 0 then
    print('clearing codes')
    txCAN(0, 0x7df, 0, {1,4})
setTickRate(1)
prefixes = {'P','C','B','U'}
function toDigit(v)
  return digits[v+1]
function printDTC(data)
  local dtc
  local a = data[3]
  local b = data[4]
  local c3 = bit.band(a, 0x0f)
  local c5 = bit.band(b, 0x0F)
  println('Found DTC: ' ..code)
function printRawDTC(data)
  print('Raw DTC bytes: ')
  println('')
function checkDTCResponse()
  local attempts = 0
  while attempts < 50 do
      if data[2] == 0x43 then
        if data[1] > 2 then
          printRawDTC(data)
          printDTC(data)
        else
          println('No DTC Found')
        return
    attempts = attempts + 1
function sendCheckDTC()
  println('Sending check DTC')
  txCAN(0, 0x7df, 0, {1,3})
  sendCheckDTC()
  checkDTCResponse()
Data filtering
Simple RPM Filter
--sample RPM at 10Hz
rpmLimit = 10000
rpm = 0
function doRPM()
  local r = getTimerRpm(0)
  if r < rpmLimit then
    rpm = r
  setChannel(rpmId, rpm)
  doRPM()
Automatic logging control
  startLogging()
  if getGpsSpeed() > 10 then
    startLogging()
  else
    stopLogging()
  if getAnalog(8) > 13 then
    startLogging()
  else
    stopLogging()
 setTickRate(30)
  local arm = getGpio(0)
  local g = getAccel(1)
  if arm == 0 then
    stopLogging()
  if arm == 1 and g < 0.1 then
    startLogging()
maxAvg = 600
--do not change
fuelAvg={}
fuel2Index = 1
function updateFuelAvg(value)
  local i
  if #fuelAvg == 0 then
    --initialize averaging table
  fuelAvg[fuel2Index] = value
  fuel2Index = fuel2Index + 1
  local sum = 0
  for i = 1, #fuelAvg do
    sum = sum + fuelAvg[i]
setTickRate(30)
  updateFuelAvg(getAnalog(0))
--10Hz update
--Create channel: "SensorAvg"
--Sample rate: 10Hz
--min/max: 0/5
--Units: "Volts"
  local a1 = getAnalog(0)
  local a2 = getAnalog(1)
Gear Calculation
setTickRate(30)
--create gear channel
  setChannel(gearId,gear)
Also available as a preset
Throttle Position Calculation
MaxAccelG = 0.30   -- Look at your logs and see what your max acceleration is in 3rd or 4th gear.  Note that full acceleration in 5th will not show 100% throttle.
function updatevThrottle()
 TPS = (AccelG/MaxAccelG)*100
 if TPS < 0 then TPS = 0 end
 TPS = math.abs(TPS)
 setChannel(chThrottle, TPS)
--10Hz update
  updatevThrottle()
Brake Position Calculation
MaxDecelG = 1.20   --Look at your logs and see what your maximum g-forces under straight line braking is and round down.
function updatevBrake()
--if ReverseAccel then
BrakeG = BrakeG *-1
 --BrakeG = -1.1
 BrakePos = math.abs(BrakePos)
 setChannel(chBrake, BrakePos)
--10Hz update
  updatevBrake()
maxRpm = 0
function rpmReset()
local rpm = getTimerRpm(0)
local clear = getGpio(0)
if rpm > maxRpm then
  maxRpm = rpm
  setChannel(maxRpmId, maxRpm)
if clear == 0 then
  maxRpm = 0
rpmReset()
Alerts/Notifications
Create an over-rev marker
  local overRev = 0
Given:
--onTick() is called at 10Hz
rpmThreshold = 2000
lowOilPressure = 15
  local shockDriver = 0
    shockDriver = 1
  setGpio(0, shockDriver)
Track Max RPM / Value
maxRpm = 0
    maxRpm = rpm
    setGpio(0, 1)
  else
    setGpio(0, 0)
or
 if getAnalog(0) > 212 then
   setGpio(0, 1)
 else
   setGpio(0, 0)
Multi warning light
   setGpio(0, 1)
 else
   setGpio(0, 0)
  • Using PWM/Analog output
 local p = 0
 setPwmDutyCycle(0,p)
  • Using GPIO in output mode
 local p = 0
 setGpio(0, p)
Given:
  • RPM sensor on timer input 0
setTickRate(15)
ProFormance Meter
setTickRate(25)
sxSetConfig(1)
yawThreshold = 25 --At what yaw rate do you want the oversteer alarm lights to trigger'  Check normal max yaw on your Podium.live race summaries to get a better idea of what value you should use
maxGsum = .3
maxLatG = .2
maxBrakeG = .2
maxAccelG = .1
currLatG = 0
longG = 0
lastLongG = 0
lastLatG = 0
function updateGStats()
		if gsum > maxGsum then
			maxGsum = gsum
	if latG ~= nil then
		latG = math.abs(latG)
		if latG > maxLatG then
			maxLatG = latG
	if currLongG ~= nil then
		if currLongG>0 then
			if currLongG > maxBrakeG then
				maxBrakeG = currLongG
		elseif currLongG<0 then
			if currLongG>maxAccelG then
				maxAccelG = currLongG
function alertYaw(Yaw)  --Light up the side ShiftX lights in case of an Oversteer event
		sxSetLed(7,2,255,255,255,9)
		sxSetLed(7,2,255,255,255,5)
		sxSetLed(7,2,255,255,255,3)
	else
		sxSetLed(7,2,0,0,0,0)
		sxSetLed(0,0,0,0,0,0)
	local cLongG =  getChannel("AccelX")
	if cLongG ~= nil then
		longG = cLongG
	local BrakeAccel = "Braking"
	local maxLongG = maxBrakeG
	--may not want to do this
	--	BrakeAccel = "Accelerating"
	--	maxLongG = maxAccelG
	--end
	local latGAvail = 0
	local longGAvail = 0
		latGAvail =  maxLatG*(1-(currLongG/maxLongG))
	else --Pro Driver
	local percGUsedLat
	if latGAvail <= 0 then
		percGUsedLat = 1
	else
	local percGUsedLong
	if longGAvail <= 0 then
		percGUsedLong = 1
	else
	local ProFormanceRating
		local TotalPot2
			TotalPot2 = 1
		else
		local TotalPot3
			 TotalPot3 = 1
		else
	else
		local TotalPot2
			TotalPot2 = 1
		else
		local TotalPot3
			TotalPot3 = 1
		else
	lastLongG = currLongG
	lastLatG = currLatG
	return ProFormanceRating
	resetSxLeds()
	sxSetLed(0,numLeds,255,0,0,0)
	sxSetDisplay(0,rating)
	resetSxLeds()
	updateGStats()
	local driverLevel = 1
	collectgarbage()
CAN bus scripts
setTickRate(30)
  id, ext, data = rxCAN(0)
  if (id ~= nil) then
    txCAN(1, id, ext, data)
Given:
  • CAN1 channel is used
  local speed = getGpsSpeed()
  local msg = {speed}
  txCAN(0, 1234, 0, msg)
Given:
  local tmp = getAnalog(0)
  local msg = {tmp}
setTickRate(30) --30Hz
        id, e, data = rxCAN(0)
		print(id ..':')
		for i=1,#data do
			print(data[i] ..' ')
		println('')
    until id == nil
Given:
  • Sets tick rate to 10Hz
  id, ext, data = rxCAN(0, 100)
CAN bus loopback test
Wiring / Setup
-- CAN loopback test
can_id = 1234
count = 0
  count = count + 1
  if id == nil then
  else
Serial Port
initSer(4, 115200, 8, 0, 1)
 value = getAnalog(0)
 writeSer(4, 'A=' ..value)
Read a line of serial data
 value = readSer(4, 100)
 if value ~= nil then
Demo Scripts
RPM Sweep
-- 05 Jan 2016 RPM demo
-- F.Mirandola - B.Picasso
thrRpmLo = 3000
thrRpmHi = 10000
incrementRpm = 300
-- Do not edit after this!!
rpm = 0
direction = 0
Simulating Laps
--use this script
et = 0 --ElapsedTime value
lt = 0 --LapTime value
pt = 0 --PredTime value
cl = 0 --CurrentLap value
lc = 0 --LapCount value
--completed a lap
if lc > 0 then
 pt = targetTime + rnd
 setChannel(ptid, pt)
et = et + 0.00166666667
setChannel(etid, et)
if et > targetTime + rnd then
 lt = et
 setChannel(ltid, lt)
 et = 0
 cl = cl + 1
 setChannel(clid, cl)
 if cl > 1 then
  lc = lc + 1
  setChannel(lcid, lc)
