RaceCapturePro Lua Scripting Examples
Revision as of 21:57, 30 October 2019 by Sbarton (talk | contribs)
API Reference
Complete API Reference
OBDII tricks
Complete OBDII PID reference
Clear current trouble codes
setTickRate(1)
count = 0
 checkClearCodes()
function checkClearCodes()
  if count % 10 == 0 then
    print('clearing codes')
    txCAN(0, 0x7df, 0, {1,4})
setTickRate(1)
prefixes = {'P','C','B','U'}
function toDigit(v)
  return digits[v+1]
function printDTC(data)
  local dtc
  local a = data[3]
  local b = data[4]
  local c3 = bit.band(a, 0x0f)
  local c5 = bit.band(b, 0x0F)
  println('Found DTC: ' ..code)
function printRawDTC(data)
  print('Raw DTC bytes: ')
  println('')
function checkDTCResponse()
  local attempts = 0
  while attempts < 50 do
      if data[2] == 0x43 then
        if data[1] > 2 then
          printRawDTC(data)
          printDTC(data)
        else
          println('No DTC Found')
        return
    attempts = attempts + 1
function sendCheckDTC()
  println('Sending check DTC')
  txCAN(0, 0x7df, 0, {1,3})
  sendCheckDTC()
  checkDTCResponse()
Display OBDII Codes as a channel and allow driver to reset the OBDII Codes with a button
This script creates a virtual channel called OBDIICodes and sets it to the first OBDII Code found (It will not have the alpha prefix (Ie P, C , B, or U), but will just have up to 4 digits. You can then use these digits to figure out the P code. Ie, if 155 is returned, your OBDII code would be P0155. If -1 is shown for the OBDIICodes channel that means RaceCapture has not received any cods from the ECU yet. If 0 is shown for OBDIICodes channel that means the ECU sent back P0000 which means there are no OBDII codes in the ECU. This channel will be logged and sent via telemetry just like a regular channel.
I also added the ability for the driver to reset the OBDII codes using an external button. This button needs to be mapped to an Analog or GPIO channel called ClearOBD. It will reset the vehicles OBDII codes and reset the OBDIICodes channel to -1.
 local ClrOBD = getChannel("ClearOBD") --Must create an analog or GPIO channel called ClearOBD in your settings and map it to read 1 or higher when you push the external button wired to that input
    txCAN(canChan, 0x7df, 0, {1,4})
function toDigit(v)
  return digits[v+1]
  local dtc
  local a = data[3]
  local b = data[4]
  setChannel("OBDIICodes", code)
  code = prefix ..code
  println('')
  local attempts = 0
        if data[1] > 2 then
          printRawDTC(data)
          printDTC(data)
        else
        return
  checkDTCResponse(1)
  checkClearCodes(1)
Data filtering
Simple RPM Filter
--sample RPM at 10Hz
rpmLimit = 10000
rpm = 0
function doRPM()
  local r = getTimerRpm(0)
  if r < rpmLimit then
    rpm = r
  setChannel(rpmId, rpm)
  doRPM()
Automatic logging control
  startLogging()
  if getGpsSpeed() > 10 then
    startLogging()
  else
    stopLogging()
  if getAnalog(8) > 13 then
    startLogging()
  else
    stopLogging()
 setTickRate(30)
  local arm = getGpio(0)
  local g = getAccel(1)
  if arm == 0 then
    stopLogging()
  if arm == 1 and g < 0.1 then
    startLogging()
maxAvg = 600
--do not change
fuelAvg={}
fuel2Index = 1
function updateFuelAvg(value)
  local i
  if #fuelAvg == 0 then
    --initialize averaging table
  fuelAvg[fuel2Index] = value
  fuel2Index = fuel2Index + 1
  local sum = 0
  for i = 1, #fuelAvg do
    sum = sum + fuelAvg[i]
setTickRate(30)
  updateFuelAvg(getAnalog(0))
--10Hz update
--Create channel: "SensorAvg"
--Sample rate: 10Hz
--min/max: 0/5
--Units: "Volts"
  local a1 = getAnalog(0)
  local a2 = getAnalog(1)
Gear Calculation
setTickRate(30)
--create gear channel
  setChannel(gearId,gear)
Also available as a preset
Throttle Position Calculation
MaxAccelG = 0.30   -- Look at your logs and see what your max acceleration is in 3rd or 4th gear.  Note that full acceleration in 5th will not show 100% throttle.
function updatevThrottle()
 TPS = (AccelG/MaxAccelG)*100
 if TPS < 0 then TPS = 0 end
 TPS = math.abs(TPS)
 setChannel(chThrottle, TPS)
--10Hz update
  updatevThrottle()
Brake Position Calculation
MaxDecelG = 1.20   --Look at your logs and see what your maximum g-forces under straight line braking is and round down.
function updatevBrake()
--if ReverseAccel then
BrakeG = BrakeG *-1
 --BrakeG = -1.1
 BrakePos = math.abs(BrakePos)
 setChannel(chBrake, BrakePos)
--10Hz update
  updatevBrake()
maxRpm = 0
function rpmReset()
local rpm = getTimerRpm(0)
local clear = getGpio(0)
if rpm > maxRpm then
  maxRpm = rpm
  setChannel(maxRpmId, maxRpm)
if clear == 0 then
  maxRpm = 0
rpmReset()
Alerts/Notifications
Create an over-rev marker
Given:
  • RPM is connected a timer channel called RPM
   local rpm =  getChannel("RPM")
Create an Impact marker
  if gsum ~= nil and gsum > 2.0 then --Assumes anything over 2.0G's is an impact.  Change to suit your needs.
function updateDiffSwitch()
	if diffTemp ~=nil and diffTemp > 180  then --update temp to turn on at
		setGpio(2,1)
		setGpio(2,0) --Uses GPIO3 for output.  Increase SampleRate or TickRate if it isn't turning on
Given:
--onTick() is called at 10Hz
rpmThreshold = 2000
lowOilPressure = 15
  local shockDriver = 0
    shockDriver = 1
  setGpio(0, shockDriver)
Track Max RPM / Value
maxRpm = 0
    maxRpm = rpm
    setGpio(0, 1)
  else
    setGpio(0, 0)
or
 if getAnalog(0) > 212 then
   setGpio(0, 1)
 else
   setGpio(0, 0)
Multi warning light
   setGpio(0, 1)
 else
   setGpio(0, 0)
  • Using PWM/Analog output
 local p = 0
 setPwmDutyCycle(0,p)
  • Using GPIO in output mode
 local p = 0
 setGpio(0, p)
Given:
  • RPM sensor on timer input 0
setTickRate(15)
ProFormance Meter
setTickRate(25)
sxSetConfig(1)
yawThreshold = 25 --At what yaw rate do you want the oversteer alarm lights to trigger'  Check normal max yaw on your Podium.live race summaries to get a better idea of what value you should use
maxGsum = .3
maxLatG = .2
maxBrakeG = .2
maxAccelG = .1
currLatG = 0
longG = 0
lastLongG = 0
lastLatG = 0
function updateGStats()
		if gsum > maxGsum then
			maxGsum = gsum
	if latG ~= nil then
		latG = math.abs(latG)
		if latG > maxLatG then
			maxLatG = latG
	if currLongG ~= nil then
		if currLongG>0 then
			if currLongG > maxBrakeG then
				maxBrakeG = currLongG
		elseif currLongG<0 then
			if currLongG>maxAccelG then
				maxAccelG = currLongG
function alertYaw(Yaw)  --Light up the side ShiftX lights in case of an Oversteer event
		sxSetLed(7,2,255,255,255,9)
		sxSetLed(7,2,255,255,255,5)
		sxSetLed(7,2,255,255,255,3)
	else
		sxSetLed(7,2,0,0,0,0)
		sxSetLed(0,0,0,0,0,0)
	local cLongG =  getChannel("AccelX")
	if cLongG ~= nil then
		longG = cLongG
	local BrakeAccel = "Braking"
	local maxLongG = maxBrakeG
	--may not want to do this
	--	BrakeAccel = "Accelerating"
	--	maxLongG = maxAccelG
	--end
	local latGAvail = 0
	local longGAvail = 0
		latGAvail =  maxLatG*(1-(currLongG/maxLongG))
	else --Pro Driver
	local percGUsedLat
	if latGAvail <= 0 then
		percGUsedLat = 1
	else
	local percGUsedLong
	if longGAvail <= 0 then
		percGUsedLong = 1
	else
	local ProFormanceRating
		local TotalPot2
			TotalPot2 = 1
		else
		local TotalPot3
			 TotalPot3 = 1
		else
	else
		local TotalPot2
			TotalPot2 = 1
		else
		local TotalPot3
			TotalPot3 = 1
		else
	lastLongG = currLongG
	lastLatG = currLatG
	return ProFormanceRating
	resetSxLeds()
	sxSetLed(0,numLeds,255,0,0,0)
	sxSetDisplay(0,rating)
	resetSxLeds()
	updateGStats()
	local driverLevel = 1
	collectgarbage()
CAN bus scripts
setTickRate(30)
  id, ext, data = rxCAN(0)
  if (id ~= nil) then
    txCAN(1, id, ext, data)
Given:
  • CAN1 channel is used
  local speed = getGpsSpeed()
  local msg = {speed}
  txCAN(0, 1234, 0, msg)
Given:
  local tmp = getAnalog(0)
  local msg = {tmp}
setTickRate(30) --30Hz
        id, e, data = rxCAN(0)
		print(id ..':')
		for i=1,#data do
			print(data[i] ..' ')
		println('')
    until id == nil
Given:
  • Sets tick rate to 10Hz
  id, ext, data = rxCAN(0, 100)
CAN bus loopback test
Wiring / Setup
-- CAN loopback test
can_id = 1234
count = 0
  count = count + 1
  if id == nil then
  else
Serial Port
initSer(4, 115200, 8, 0, 1)
 value = getAnalog(0)
 writeSer(4, 'A=' ..value)
Read a line of serial data
 value = readSer(4, 100)
 if value ~= nil then
Demo Scripts
RPM Sweep
-- 05 Jan 2016 RPM demo
-- F.Mirandola - B.Picasso
thrRpmLo = 3000
thrRpmHi = 10000
incrementRpm = 300
-- Do not edit after this!!
rpm = 0
direction = 0
Simulating Laps
--use this script
et = 0 --ElapsedTime value
lt = 0 --LapTime value
pt = 0 --PredTime value
cl = 0 --CurrentLap value
lc = 0 --LapCount value
--completed a lap
if lc > 0 then
 pt = targetTime + rnd
 setChannel(ptid, pt)
et = et + 0.00166666667
setChannel(etid, et)
if et > targetTime + rnd then
 lt = et
 setChannel(ltid, lt)
 et = 0
 cl = cl + 1
 setChannel(clid, cl)
 if cl > 1 then
  lc = lc + 1
  setChannel(lcid, lc)
