Remote Coaching with Race Capture
Using telemetry data and live streaming video, coaches can use these tools to coach live remotely, either from the pits at the track or from the comfort of their home offices or just about anywhere you have an internet connection. Autosport Labs Race Capture and Podium Connect devices stream data logging data to Podium.live website for instantaneous live telemetry data. This data can be viewed anywhere with a web browser or the Podium app. You can also use a cheap camera with a hotspot to stream live video to YouTube. You can then add this live streaming video to your Podium event page to be able to see live streaming data and video in one place. You can use the live telemetry data to quickly find areas for improvement, and then use live video to quickly see what they are doing that needs improvement and communicate this feedback instantaneously to your student/client via cell phone.
Please note: YouTube live streams have around a 40 second delay, so you cannot use the video for live instructing. There is no delay in the data telemetry so you can analyze the data and video and when you see them coming up to the section in question on the live data again, you can tell them what to work on this time around.
Initial Setup
Race Capture Setup
  • Go to YouTube.
Yi 4k Setup for auto streaming
  • Download this Yi4KAutoStream.zip file and copy the contents of the unzipped files onto a micro SD card. (note GB size does not matter. you cannot live stream and record video to SD card at same time)
    • Replace YOUR_SSID_HERE with the SSID of your WiFi Hotspot. (Push the button on the Hotspot to get info)
    • Note: You may want to change the SSID and Password on your Hotspot before doing this. See the documentation that came with your hotspot for information on how to do this.'
    • Replace YOUR_RTMP_URL_HERE with your full YouTube Stream URL including the StreamID appended to it. It should look like rtmp://a.rtmp.youtube.com/live2/abcd-efgh-ijkl-mnop-qrst (replace abcd-efgh-ijkl-mnop-qrst with your StreamKey)
