Remote Coaching with Race Capture
Initial Setup
Race Capture/Track Setup
  • Go to YouTube and sign in.
(should look something like this rtmp://a.rtmp.youtube.com/live2/abcd-efgh-ijkl-mnop-qrst ) YTStreamKey.png
Yi 4K Setup for Best Video
  • Update Camera Firmware
    • Download the latest Firmware for YI 4K Action Camera
    • Save the file to the MicroSD card and change the name to firmware.bin
    • Resolution: 1080/60
    • Field of View: Wide
    • Metering Mode: Average
    • Video Quality: High
    • WB: Auto
    • Go into Wifi settings:
    • Default Camera Mode: Video
    • Brightness: High
    • Beeps: High
    • Mic: Low
    • Sound Effect: Wind
    • Video Standard: NTSC
    • In Advanced set:
      • Screen Auto Lock: 60s
      • Auto Power Off: 10Min
      • Set Date and Time
      • Battery percentage: On
  • Download this File:Yi4KAutoStream.zip and copy the contents of the unzipped files onto a micro SD card. (note GB size does not matter. you cannot live stream and record video to SD card at same time)
4G WiFi Hotspot notes
Event Setup
Charge hotspot and camera and mail out equipment to client
  • Race Capture/Track
  • Yi 4K Camera
  • Camera mounting equipment
  • USB Charger and all 3 cables
  • Velcro
Podium.live Event Setup
  • Login to Podium.live and go to Events and click on Create a new event
    • Login to YouTube
    • Click Videos on the side navigation, and then Live under Channel videos.
    • Click on the pencil icon next to your Remote Coaching live stream to go into the edit details page.
    • Under Video link, copy the last portion of the URL that contains random letter/numbers. (ie. youtu.be/XpajniKJi_Y)This is your live stream VideoID.
