Remote Coaching with Race Capture
Revision as of 18:36, 23 May 2020 by Sbarton (talk | contribs)
Please note, this HowTo article is very long, but I made it pretty verbose so it would be idiot-proof ;)
Initial Setup
Race Capture/Track Setup
  • If you have any issues, you can ask questions here.
  • Go to YouTube and sign in.
Yi 4K Setup for Best Video
  • Update Camera to latest Firmware (required for auto streaming to work)
    • Download the latest Firmware for YI 4K Action Camera
    • Save the file to the MicroSD card and change the name to firmware.bin
    • Resolution: 1080/60
    • Field of View: Wide
    • Metering Mode: Average
    • Video Quality: High
    • WB: Auto
    • Go into Wifi settings:
    • Default Camera Mode: Video
    • Brightness: High
    • Beeps: High
    • Mic: Low
    • Sound Effect: Wind
    • Video Standard: NTSC
    • In Advanced set:
      • Screen Auto Lock: 60s
      • Auto Power Off: 10Min
      • Set Date and Time
      • Battery percentage: On
  • Download this File:Yi4KAutoStream.zip and copy the contents of the unzipped files onto the micro SD card. (note GB size does not matter. you cannot live stream and record video to SD card at same time)
4G WiFi Hotspot notes
Learn to use Podium to coach
Event Setup
Podium.live Event Setup
  • Login to Podium.live and go to Events and click on Create a new event and fill out details.
    • Login to YouTube
    • Click Videos on the left side navigation, and then Live under Channel videos.
    • Click on the pencil icon next to your Remote Coaching live stream to go into the edit Details page.
    • Under Video link on the right, copy the last portion of the URL that contains random letter/numbers. (ie. youtu.be/XpajniKJi_Y)This is your live stream VideoID.
RaceCapture/Track Setup
  • You should not need to make any changes to the RC/T from the initial setup, but you should make sure your previous client did not make any changes. Using the Race Capture app, you can Open and Write the config file you previously saved to make sure.
  • You do not need OBDII or CAN data from your clients car, but if you like, you can add it via the CAN Bus, CAN Mapping, and OBDII sections in the Race Capture App. Click Presets, then click Update then select the Preset for their car or ECU if available.
  • Please see the RaceCapture/Track Install instructions as well as the OBDII Instructions for more info on how to get CAN/OBDII data from your car.
Test Setup (optional)
  • Power on the RaceCapture/Track with mini USB or OBDII dongle
  • Connect your internet connected phone/tablet/computer to RaceCapture/Track
  • Open Race Capture app and go into Settings-->Preferences and make sure RaceCapture connection type is set correctly and that Send Telemety is ON
  • Go to Dashboard and scroll to All Raw Channels view to make sure it is connected and everything is working (you should see some valid data and green cloud icon).
  • Power on Hotspot and wait until it us up and running
  • Power on Yi 4K Camera and start recording
  • Go to YouTube and check to see if you see the live video stream
  • Get the Live Stream ID from YouTube. See instructions above.
  • Go to Podium.live and click on Events
  • The very top event should be an ad hoc event with today's date. Click on it.
  • Click on the Edit icon next to your device name.
  • Add your YouTube live streaming URL in the Video Embed field and Update device event information.
  • This should take you to your device event page where you can see the live streaming data and video. If it did not take you to this page, from the Event page, click on your device name.
  • Camera mounting equipment
  • USB Charger and all 3 cables
  • You may also want to email out the URL to the Podium.live event webpage and/or the Youtube link to the live streaming video.
  • Install latest Race Capture app for Android, FireOS, or iOS on client's cellphone or 4G tablet.
  • Power on the RaceCapture/Track either with mini USB cable or OBDII dongle.
  • Connect the phone/tablet to the RaceCapture/Track device either with Bluetooth (Android) or WiFi (iOS).
  • Open Race Capture app on phone and do the following:
    • Click Hamburger menu icon top left and go to Preferences and set the following:
      • Startup Screen: Dashboard
      • Record Session: On
      • Send telemetry: On (client's cell phone/4G tablet will send the data telemetry, not the hotspot. data telemetry uses minuscule amounts of data)
      • RaceCapture connection type: Set this to the type of connection you used to connect your phone/tablet to the RaceCapture/Track (probably Bluetooth for Android and WiFi for iOS).
      • You may need to restart the Race Capture app for the connection type to take effect
  • Once the Race Capture phone app has connected to the RaceCapture/Track device, click the hamburger icon top left and click Setup
    • Under Race Tracks:
      • Turn on Automatic race track detection
      • Click the Edit icon bottom right
      • Click Update and wait for update to complete (may take a minute)
      • Search and select the track you will be going to. If there are multiple configurations, make sure you only select the one you are going to. If you will be driving multiple configurations, select the entire track that has most/all the configurations.
    • Click Write to write the changes to RaceCapture/Track
    • Go to Dashboard and scroll until you get to the Predictive Lap timing dashboard
  • Install the camera mount in your car with the included roll bar RAM mount or headrest RAM mount. Optimal position is at eye height or higher with a clear view out of the windshield and view of the steering wheel and if possible the pedals and/or shifter.
  • If you have a secure mount for your phone/tablet ideally place it in view of the camera if possible
  • Install/mount the WiFi Hotspot in your car where you can see status and turn it on and off fairly easily. Use supplied Velcro if needed for temporary install.
  • Securely mount the RaceCapture/Track in the center of your car, ideally on the trans tunnel with the USB port and RJ45 port facing the front of the car, and GPS antenna plug facing the rear of the car. You can use Velcro to secure it.
  • Plug the OBDII cable into your vehicles OBDII port if available, and plug the other end into the RaceCapture/Track device. If you do not have OBDII, that is OK, use the supplied mini USB cable to power the RaceCapture/Track instead.
  • Plug the GPS antenna into the RaceCapture/Track device and mount it in clear view of the sky. It has a magnet mount if needed. Make sure it is mounted away from any racing radio antennas.
  • Plug in the supplied USB charger and plugin and run the supplied micro USB cables to power the camera and the hotspot. If you do not have an OBDII port, you can power the RaceCapture/Track with the supplied mini USB cable.
  • Contact your coach if you would like to test the setup.
  • Make sure your phone headset works under your helmet and is charged.
  • Make sure everything is powered off when done so that the batteries do not die.
Equipment Setup at the Track
  • Make sure everything is still plugged in
  • Power on the WiFi Hotspot
  • RaceCapture/Track should automatically power on when the car is turned on or power applied to USB charger if plugged into that.
  • Plug in or pair your headset to your phone.
  • Open RaceCapture app on your phone or 4G tablet and make sure it pairs with the RaceCapture/Track device.
  • Navigate to the Predictive Lap timing Dashboard if not already there. You will see a green cloud icon top right to know it is connected to and can stream live data to Podium.live
  • If you have a secure mount for your phone/tablet, safely mount it where you can see it. If possible place it where the camera can see it as well. The predictive lap timing with lap delta bar is a good tool to help find time and consistency.
  • If you cannot safely mount your phone/tablet in view, do not worry. Secure it safely somewhere in the car. However the phone must be on with the app running for the data telemetry to work.
  • Plug in your phone to keep it charged. (The screen will be on so it will use up the battery)
  • Turn on the camera and when ready to leave the pits, press the record button. You should see the LED light on the front light up red/purple.
  • Please note, streaming video consumes A LOT of data. Please only stream video when you are getting ready to go on track and turn it off immediately when you get back to the pits.
  • Call your coach so he can coach you while on the track.
Remotely Coaching
  • Print out a copy your clients schedule to know when they will be on track.
  • Go to Podium.live and click on Events.
    • Click on the event you created for this.
    • Click on the Device Name to bring up the live data and video.
  • If you have 2 screens bring up the live video in YouTube.
    • Go to YouTube and go to your channel. You should see your current live stream there. If not go to YouTube Studio --> Videos --> Live
  • If you have any issues, you can get help here.
