RaceCapturePro Sensors
Revision as of 20:47, 3 April 2026 by Brentp (talk | contribs) (Remapping channels)
IMU (Accelerometer / Gyro)
Systems with an on-board IMU should be mounted in the default orientation, typically with the device connectors oriented towards the front of the vehicle.
  • Note Check the model's documentation for the specific mounting guide.
Mounting in an alternate orientation
  • Inverted mounting
  • Flat / upright, but rotated 90 degrees
  • On-edge, but aligned with the front-rear axis of the vehicle
Re-orientation requires re-mapping of the accelerometer channels using the RaceCapture app.
Re-orientation procedure
Preparation
Prior to remapping, create a temporary RaceCapture dashboard with the 6 channels (AccelX, AccelY, AccelZ, Yaw, Pitch, Roll).
Detach the system from the vehicle and visually note the behavior of each channel by moving the system about in free air. See the diagram for reference:
Remapping channels
Smoothing
  • Less (slider to the left): Minimal filtering, producing raw and highly responsive data. This is useful for capturing sharp, short-duration events such as curb strikes or sudden inputs, but may introduce more noise into the signal.
  • More (slider to the right): Increased filtering, producing a smoother signal by averaging out rapid fluctuations. This is better suited for general handling analysis where a cleaner trace is preferred.
Adjust the smoothing level to suit your logging and analysis goals. For most track driving applications, a moderate smoothing setting is a good starting point.
Zero Calibration
Pullup Resistor
Sensor Ground
  • Thread Size : 1/8″ NPT
  • Cable length : 1 Meter
  • Voltage supply : 3-5V
  • Thread Size : 3/8" NPT
  • Cable length : N/A
  • Body Material : Copper
  • Pigtail :Pico 5616pt
  • Body Material : Brass
  • Voltage supply : 5V
  • Datasheet :Click here
Pressure Sensors
  • Cable length : 2 Meter
  • Mfg / Prt : AEM 30-2131-150
  • Data Sheet : Click here
  • Mfg / Prt : 12223861 (GM)
  • Output : 0.2 to 4.9 V
Pulse/Speed/RPM Sensors
  • Power
  • Ground
  • Signal Output
Wiring the Speed Sensor
Recommended RPM Sensor
  • Mfg / Prt : ASL_COILX
  • Mfg / Prt : Hamlin 55505
  • Datasheet : Click here
  • Mfg / Prt : Cherry GS100701
  • Thread Size : 15/32-32
  • Supply Voltage : 5 to 24 V
  • Supply Current : 3 to 6 mA
  • Body Material : Aluminum
  • Output current : 25mA max
Distance Sensors
  • Cable : 2 meter cable
  • Range : 10K ohm range
  • Mfg / Prt : Sharp GP2D12
  • Detecting Range : 10-80cm
  • Mfg / Prt : BMW 37140141444
  • Pigtail : 61138383300
  • Voltage Supply : 5V
[ KA Sensors RHL3 : Laser Ride Height Sensor]
Step To Calibrate :
Create Calibration Table:
Angle/Rotation Sensors
  • Mfg/Prt : Ford / SMP TH45
  • Pigtail : Pico 5752PT
  • Supply Voltage : 5V
Fuel Level Sensor
Fuel level sensor calibration
  • 0%
  • 25%
  • 50%
  • 75%
  • 100%
Smoothing the channel to deal with slosh
Alternative Fuel level senders
Fuel level senders with 0-5v signal output
Air/Fuel Ratio Sensor
  • Mfg/Prt : Texense LSU 4.9
  • Pigtail : Built-in wiring
Thermal Sensor
Recommended Thermal Sensors
[ASL_TIREX_4PACK / ASL_TIREX_SINGLE : TireX advanced thermal sensor ]
  • Accuracy : 1C
  • Supply voltage : 6 – 12v
  • Power : 200mW
  • Interface : CAN 2.0
SensorX sensor breakout board
  • Dimensions: 0.4″ x 4″
  • Five 2.2K resistors
Wiring Analog Sensors
Calibrating Analog Sensors
Linear Sensors
Example : 150 PSI pressure sensor
  • 0.5 v = 0 PSI
  • 4.5 v = 150 PSI
Curved Sensors
Example : Extended range temperature sensor with 5v reference and 2.2K pullup resistor
  • 0.4 v = 302 F
  • 0.87 v = 239 F
  • 1.88 v = 176 F
  • 3.2 v = 122 F
  • 4.72 v = 32 F
Fuel Level Sensors
Calibration
  • Empty (0%)
  • 1/4 (25%)
  • 1/2 (50%)
  • 3/4 (75%)
  • Full (100%)
Set up the Analog Channel
