Ford EDIS technical information
Revision as of 20:23, 19 August 2009 by RelboGetch (talk | contribs)
http://basdarnolir.com/eltcnatrdom.html[zeldelouge] [[1][zeldelouge]]
"zeldelouge":http://letozellil.com/varoroloric.html
Ford EDIS general information
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Interfacing with OEM Tach
Tach circuit
Trigger Wheel Designs
Adapting OEM trigger wheel
Alternate coil wiring
