MegaJolt Lite Jr.
Revision as of 05:51, 25 March 2007 by Brentp (talk | contribs) (minor edits)
The Megajolt Lite Jr. (MJLJ) is a fully configurable, stand-alone ignition controller designed to control a Ford EDIS 4, 6 or 8 crank-fired ignition module. It is an ideal ignition solution for carburated engines; it can also work in conjunction with compatible EFI systems.
Current Features
  • External Rev-Limit trigger output (The Ford EDIS module has no 'rev limit' signal, so an external circuit to disable the ignition coil is required)
  • Modern, easy to use, and customizable Windows-based configuration software
    • Load, configure and save Ignition Configuration
New with V2.7.x/V3.1.0 beta
  • TPS / Load axis calibration
  • Improved user outputs with hysteresis
Current Hardware
Version 3.x
Older hardware revisions
Version 2.x
Ancient History
