MegaJolt Lite Jr.
Revision as of 01:01, 22 April 2007 by Brentp (talk | contribs) (→‎New with V2.7.x/V3.1.0 beta: bumped version number)
The Megajolt Lite Jr. (MJLJ) is a fully configurable, stand-alone ignition controller designed to control a Ford EDIS 4, 6 or 8 crank-fired ignition module. The result is a precision, digitally controlled distributorless ignition system.
Current Features
  • External Rev-Limit trigger output (The Ford EDIS module has no 'rev limit' signal, so an external circuit to disable the ignition coil is required)
  • Modern, easy to use, and customizable Windows-based configuration software
    • Load, modify and save Ignition Configuration
New with V2.8.x/V3.2.0
  • TPS / Load axis calibration
  • Improved user outputs with hysteresis
Current Hardware
Version 3.x
MjljV3 MAP prebuilt.jpgMjlj v3 build step6 map.jpgMjlj v3 build step5 map.jpg
Older hardware revisions
Version 2.x
Mjlj v2 molex end.jpgMjlj v2 open case closeup2.jpgMjlj assembly complete.jpg
Ancient History
