RaceCapture App User's Guide
Planned support:
- OS X
- Android: Beta available, contact us a [email protected] for access
- iOS
Downloads
Discussion Forums
In the spirit of sharing and collaboration, please post all of your questions / feedback in the community forums.
RaceCapture V2 App/Firmware Discussion Forum
Check out some kickass features:
Capable of running on Windows and Android, the new RaceCapture app will ultimately combine RaceAnalyzer and the current Mobile app into a unified configuration, dashboard and analysis solution.
The latest race track configurations can be automatically downloaded and synchronized from http://www.race-capture.com via the application. If your track is not in the list, email us at [email protected] and we will work to get it added.
Multi-Sector Timing
Separate Start/Finish Lines
To enable auto-x/rally/hillclimb scenarios we've enabled the ability to define a separate start and finish line.
Predictive Lap Timing
CAN bus expansion
OBD2 support
Virtual Channels
Lua Scripting
- Use the print() and println() to print out log messages which will show up in the scripting view. Great for debugging.
- If a wayward script somehow crashes the firmware, the RCP watchdog will fire and start up RCP in safe mode, illuminating the red LED and bypassing script execution. Then, you'll have a chance to make fixes.
- Functions have been streamlined and normalized for consistency. Additional Lua functions have been added to support virtual channels, OBDII and CAN bus messaging.
Read more in our Lua Scripting Guide
Improved log timing accuracy
Upcoming Features
Dashboard
- Multi-gauge dashboard view
Firmware
- Windows: Check under Device Manager for a RaceCapture/Pro device under the Ports section.
- Linux: When plugged in, a CDC-ACM device should show up. Check it by issuing the dmesg command; typically it will be /dev/ttyACM0
Application
Install the RaceCapture app after downloading the setup package from the downloads section
Running
Editing Configuration
Auto track detection
GPS Configuration
Analog Channels
- Raw value
- Simple linear scaling
- Interpolated map
- Note Channel #8 is fixed as a battery input channel and should not be changed.
Pulse/RPM Sensors
- Channel Operation Mode: RPM, frequency, or pulse period
- Clock divider: This specifies the operating range for measuring the pulse. This is typically left at 128.
- Pulse Per Revolution / Teeth Per Wheel: This specifies the number of pulses representing a complete revolution of the wheel.
- For RPM mode This value is typically set based on the number of cylinders and the number of coil packs used on the engine
Digital In/Out
- Mode: Set the channel to input for reading digital on/off sensors, or output to use the channel in output mode to control a device.
Accelerometer/Gyro
Pulse/Analog Out
- Output Mode Select either Frequency / Pulse Width Modulated (PWM) mode or analog output mode. Note, to enable analog mode you also need to flip the hardware dip switch on the RaceCapture/Pro main board.
- Logging Mode Select either logging the frequency or the analog output voltage.
- Startup Duty Cycle The default duty cycle when the system starts up.
- Startup Period The default startup value for the pulse period. A larger number means individual pulses are spread further apart.
CAN Bus
OBD II
Bluetooth
You can enable Bluetooth via the Wireless settings. After enabling and saving the configuration to RaceCapture/Pro, following these steps:
- Install the Race Capture app on your Android device from the Google Play Store
- Turn on Bluetooth on your tablet and pair with RaceCapture/Pro, password is 1234
- Open the RaceCapture app, tap the screen until the RaceCapture logo show up at the top.
- Tap the Bluetooth icon at the top right
- Select RaceCapture/Pro
- After a few seconds you should see a 'Connected to RaceCapture/Pro' message and data will be transmitting to your tablet.
- Swipe to the digital dash screen and you should see values changing, pick up your RaceCapture/Pro and move it around, you should see even more sensors changing!
Telemetry
For detailed setup instructions read our Telemetry Quickstart
Scripting
LuaScripting for RaceCapture/Pro enables unlimited capabilities for your data logging and control requirements. Create a virtual/math channel or control an airbrake or intercooler sprayer. For full information about how to write Lua Scripts, read our Lua Scripting Guide
Use the print() and println() to print out log messages which will show up in the scripting view. Great for debugging!
