CAN Bus Integration
Revision as of 16:18, 26 February 2015 by Brentp (talk | contribs) (→MSB or LSB mode: fixed derp)
Mapping an existing CAN bus system can be easy if documentation is available. ECU manufacturers are especially keen on providing documentation as they want their devices to easily connect to other systems, such as data systems and dashboards.
If documentation isn't available, the problem is just more interesting. Fortunately the CAN bus system is open in terms of it's messaging format and provides simple 8 byte message packets ident with a numeric identifier, much like an internet address, but a smaller number.
Researching CAN Bus protocol
If you are working to integrate an ECU, first ask the manufacturer for their CAN bus specification. This documentation will provide a breakdown of channels - such as RPM, temperatures and pressures and describe how they appear in the CAN message stream. A good example is the Megasquirt CAN Broadcast Specification
CAN Bus documentation
This document will show for each channel the following information:
  • Channel: (RPM, Engine Temperature, Throttle Position, etc)
  • CAN Identifier: The CAN Identifier for each channel. This may appear in either 11 or the extended 29 bit format. Typically 11 bits are used.
  • Offset: where the data starts within the 8 byte CAN message. An offset of 0 means the data starts on the first byte.
  • Length: Typically 1 or two bytes
  • Scaling: The raw value from the message is often scaled to a real world value. Typically this is provided as a multiplier and adder value.
MSB or LSB mode
Additionally, the manufacturer will specify if multi-byte (16, 24 or 32 bit) values are presented in MSB (Most Significant Bit) or LSB (Least Significant Bit) mode.
MSB mode data will have the high byte presented first in the data packet and is typically the most common format.
Example:
  • Decimal value: 1000
  • Hex Value in MSB: 0x03E8
  • Hex Value in LSB: 0xE803
MSB format:
  • Offset 1
  • Length 2
  • Data:
(Hex)     [xx] [03] [E8] [xx] [xx] [xx] [xx] [xx]
(Decimal) [xx] [3] [232] [xx] [xx] [xx] [xx] [xx]
LSB format:
  • Offset 1
  • Length 2
  • Data:
(Hex)     [xx] [E8] [03] [xx] [xx] [xx] [xx] [xx]
(Decimal) [xx] [232] [3] [xx] [xx] [xx] [xx] [xx]
Reverse Engineering
Reverse engineering is possible, providing you can log a data stream from the device and compare it against direct measurements.
Common Approach
  • Log all messages from the CAN bus
  • Directly measure or observe a sensor channel and compare it against changes in the CAN bus data, watching for patterns.
Example
An example for decoding RPM: To detect which CAN message contains RPM, log CAN messages while simultaneously directly logging RPM, synchronizing the messages and the direct RPM measurement in time. Observing CAN message data changing in sync with direct RPM measurements will pin point which messages and data values contain RPM.
Logging Data
Mapping CAN data to Virtual Channels
Reading a CAN message
id, ext, data = rxCAN(0, 100)
Mapping to a Virtual Channel
  • Set up the channel. Example "EngineTemp"
  • Read a CAN message
  • Extract a value from the data fields
  • Scale the extracted value to a real world value (Example: Degrees F)
  • Set the virtual channel with the scaled value
  • Example: Set MyChannel from CAN ID 1234. Data is in the first byte of the message.
  id, ext, data = rxCAN(0)
  if id == 1234 then
CAN integration framework
Below is a script framework to ease mapping of CAN bus data to virtual channels. You can copy the script and modify as you need. This example showcases mapping some of the BMW E46 CAN bus channels:
tickRate = 30
--the CAN baud rate
CAN_baud = 500000
CAN_chan = 0
be_mode = 0
CAN_map = {
    processCAN(CAN_chan)
function processCAN(chan)
    repeat
            local map = CAN_map[id]
            if map ~= nil then
                map(data)
    until id == nil
    offset = offset + 1
    local value = 0
    local shift = 1
    while len > 0 do
        shift = shift * 256
        offset = offset + 1
        len = len - 1
    offset = offset + 1
    local value = 0
    while len > 0 do
        offset = offset + 1
        len = len - 1
initCAN(CAN_chan, CAN_baud)
