RaceCapturePro Downloads
RaceCapture App
- For MK1 and MK2 versions of RaceCapture/Pro
- MK1 users: ensure you have updated to the latest V2 firmware.
Windows
Requires: Windows 7+; 2GB RAM; OpenGL 2.0 graphics support
Note: The app will fail to launch if OpenGL 2.0 graphics are not supported. If this happens try updating your graphics driver.
Mac OS X
Requires OSX 10.6+
Unzip the file and copy the RaceCapture app to your Applications directory.
This is a beta it may crash or have unexpected behavior. Please file bugs on our forums here http://www.autosportlabs.org/viewforum.php?f=33
Linux
Packages coming soon!
Mobile App
USB Driver
- OS X: No driver needed
- Linux: No driver needed
RaceCapture/Pro MK2
Firmware
RaceCapture/Pro MK1
- Note* For Mac users you will need to use a Windows VM to connect to RCP. Free virtual machine images are available here: http://dev.modern.ie/tools/vms/ You will need to add a network adapter to the VM. After that follow the Windows instructions.
Firmware
The V2.x.x firmware for MK1 is considered 'stable beta' - We feel it's much better quality than the previous 1.2.x firmware and RaceAnalyzer combination, but since it is the first V2 firmware and app release for MK1, we are officially calling it Beta. Please visit the Discussion / support forum for help.
MK1 Bootloader Releases
Firmware update utility
