RaceCapturePro Downloads
RaceCapture App
  • Use the RaceCapture App to configure and visualize data from your RaceCapture/Pro device.
    • MK1 users: ensure you have updated to the latest V2 firmware.
Windows
RaceCapture app downloads
Requirements: Windows 7+; 2GB RAM; OpenGL 2.0 graphics support
  • The app will fail to launch if OpenGL 2.0 graphics are not supported. If this happens try updating your graphics driver
Windows USB Driver
Mac OS X
Requirements: OSX 10.6+
Unzip the file and copy the RaceCapture app to your Applications directory.
Android
Beta app: You can run the latest app in Beta by participating in the Beta program. Instructions:
  1. Using a desktop browser (or mobile in desktop mode) go to the Autosport Labs Beta testers and request to join
  2. Enroll in the Beta by following the instructions at the top of the group (or follow instructions [https://play.google.com/apps/testing/com.autosportlabs.racecapture
iOS
IOS support coming in a future release.
Linux
Packages forthcoming; meanwhile run from source from the github repository
RaceCapture/Pro MK2
Firmware
Previous Versions
How To Update Firmware
RaceCapture/Pro MK1
Note: For Mac users you will need to use a Windows VM to connect to RCP. Free virtual machine images are available here: http://dev.modern.ie/tools/vms/ You will need to add a network adapter to the VM. After that follow the Windows instructions.
Firmware
The V2.x.x firmware for MK1 is considered 'stable beta' - We feel it's much better quality than the previous 1.2.x firmware and RaceAnalyzer combination, but since it is the first V2 firmware and app release for MK1, we are officially calling it Beta. Please visit the Discussion / support forum for help.
Previous Versions
MK1 Bootloader Releases
Firmware update utility
