AutomaticCameraControl
Revision as of 22:39, 24 May 2016 by Brentp (talk | contribs)
GoPro WiFi control
This guide enables automatic start / stop control of WiFi enabled GoPro cameras using a speed based trigger.
When WiFi is enabled on your GoPro camera it creates a network that other devices can connect to. RaceCapture/Pro with the optional WiFi module can connect to this network and issue the appropriate commands to control various camera functions - in this case, starting and stopping video recording.
Starting and stopping the GoPro can controlled by a variety of means: speed, RPM or based on other sensor data - all using a Lua Script running on RaceCapture/Pro. This guide focuses on using GPS speed to trigger the camera; for triggering on other sensors see the Lua scripting guide as a reference for what other sensor data is available.
Requirements
  • RaceCapture/Pro WiFi module
  • WiFi capable GoPro Hero camera, with WiFi enabled
  • GPS Connectivity for speed measurement
Steps
Upgrade your firmware
Upgrade to the latest firmware if necessary. This guide was developed with firmware version 2.9.1.
Configure your GoPro
Connect the WiFi module
Connect the RaceCapture/Pro WiFi module to the outermost port of RaceCapture/Pro. When powered up, you should see the power LED illuminate.
Enable Lua Script for GoPro connectivity
Steps:
Lua Script
Customization
You will need to edit the following fields at the minimum, located at the top of the script
Required
Optional
goproPwd = '12345678'
goproSsid = 'aslhero1'
goproStart = 10
goproStop = 5
--How fast we check, in Hz
tickRate = 10
debug = 0
--DO NOT EDIT BELOW
port = 4
--indicates wifiStatus
wifiStatus = 0
lastInitTime = 0
initTimeout = 20000
function logMsg(msg)
  println('[GoProWiFi] ' ..msg)
function sendCrlf()
  writeCSer(port, 13)
  writeCSer(port, 10)
function sendRaw(val)
  for i=1, #val do
function sendAt(val)
  sendRaw(val)
  sendCrlf()
function toInt(val)
  return string.sub(val, 1, -3)
function httpGet(url)
  sleep(500)
  sleep(100)
  sendRaw(get)
  sleep(100)
  sendAt("AT+CIPCLOSE")
function startGoPro()
  logMsg('start GoPro')
  sendGoProShutter('01')
function stopGoPro()
  logMsg('stop GoPro')
  sendGoProShutter('00')
recording = 0
function initWiFi()
  logMsg('initializing')
  sendAt('AT+RST')
  sleep(2000)
  sendAt('AT+CWMODE_CUR=1')
  sleep(1000)
  wifiStatus = 1
function processIncoming()
    wifiStatus = 2
    wifiStatus = 3
    logMsg('ready for GoPro')
function checkGoPro()
  if wifiStatus == 0 then
    initWiFi()
    lastInitTime = getUptime()
    return
    wifiStatus = 0
  processIncoming()
  if wifiStatus ~= 3 then
    return
  trigger = getGpsSpeed()
    startGoPro()
    recording = 1
    stopGoPro()
    recording = 0
  checkGoPro()
