RaceCapturePro Lua Scripting Examples
API Reference
OBDII tricks
Clear current trouble codes
setTickRate(1) count = 0 function onTick() checkClearCodes() end function checkClearCodes() if count % 10 == 0 then print('clearing codes') txCAN(0, 0x7df, 0, {1,4}) end end
Data filtering
Simple RPM Filter
Automatic logging control
function onTick() if getAnalog(8) > 13 then startLogging() else stopLogging() end end
--The real analog channel should be named --something other than FuelLevel fuel2Id = addChannel("FuelLevel", 10, 0, 0,100,"%") --change this to make a bigger averaging window maxAvg = 600 --600 = 20 seconds averaging at 30Hz tick rate --do not change fuelAvg={} fuel2Index = 1 function updateFuelAvg(value) local i if #fuelAvg == 0 then --initialize averaging table for i = 1, maxAvg do fuelAvg[i]=0 end end fuelAvg[fuel2Index] = value fuel2Index = fuel2Index + 1 if fuel2Index > maxAvg then fuel2Index = 1 end local sum = 0 for i = 1, #fuelAvg do sum = sum + fuelAvg[i] end setChannel(fuel2Id, sum / maxAvg) end setTickRate(30) function onTick() updateFuelAvg(getAnalog(0)) end
--10Hz update setTickRate(10) --Create channel: "SensorAvg" --Sample rate: 10Hz --Logging precision: 2 decimal points --min/max: 0/5 --Units: "Volts" avgId = addChannel("SensorAvg", 10, 2, 0, 5, "Volts") function onTick() local a1 = getAnalog(0) local a2 = getAnalog(1) setChannel(avgId, (a1 + a2) / 2) end
Gear Calculation
--Developed by Luther Lloyd III 8/22/14 for use by Autosport Labs Community --Copy this text into the scripting window of Race Analyzer --Edit the gear ratios to mathc your car --Add another gear row if needed for 6th gear or delete extraneous ones --below values are constants for the vehicle local _1stGear = 3.5 local _2ndGear = 2.7 local _3rdGear = 2.0 local _4thGear = 1.4 local _5thGear = 0.9 local FinalDrive = 3.21 --diameter in inches local TireDia = 25.0 --allowable error of gear ratio to allow for measurement variation local gearErr = 0.1 local rpmSpeedRatio = 0 --initialized to 0 so if it doesn't work you know local gearPos = 0 --this is the gear channel variable function onTick() --updates gear position every second by default --assumes Pulse Input channel one is for the RPM signal and speed in MPH local speed = getGpsSpeed() local rpm = getTimerRpm(0) --this part only works for firmware version 2.0 per the RCP page gearId = addChannel("Gear",5) if speed > 10 then --makes sure your rolling so as not to divide by 0 rpmSpeedRatio = (rpm/speed)/(FinalDrive*1056/(TireDia*3.14159)) if ((_1stGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 1 end if ((_2ndGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 2 end if ((_3rdGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 3 end if ((_4thGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 4 end if ((_5thGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 5 end else gearPos = 0 end setChannel(gearId, gearPos) --outputs to virtual channel end
Alerts/Notifications
Create an over-rev marker
setTickRate(10) overRevId = addChannel("OverRev", 10) function onTick() local rpm = getTimerRpm(0) local overRev = 0 if rpm > 8000 then overRev = 1 end setChannel(overRevId, overRev) end
Given:
Track Max RPM / Value
or
Multi warning light
- Using PWM/Analog output
- Using GPIO in output mode
Given:
- RPM sensor on timer input 0
CAN bus scripts
setTickRate(30) function onTick() id, ext, data = rxCAN(0) if (id ~= nil) then txCAN(1, id, ext, data) end end
Given:
- CAN1 channel is used
Given:
Given:
- Sets tick rate to 10Hz
Serial Port
Read a line of serial data
Demo Scripts
RPM Sweep
-- 05 Jan 2016 RPM demo -- F.Mirandola - B.Picasso -- This code will show a demo RPM sweep on RaceCapturePro thrRpmLo = 3000 --Low RPM threshold for change direction thrRpmHi = 10000 --Hi RPM threshold for change direction incrementRpm = 300 --Step between each RPM increment/decrement, will affect the speed, higher = faster -- Do not edit after this!! setTickRate(10) rpm = 0 direction = 0 rpmId = addChannel("RPM", 10, 0, 0, 10000) function onTick() setChannel(rpmId, rpm) if (rpm<=thrRpmHi and direction == 0 ) then rpm = rpm + incrementRpm elseif (rpm>=thrRpmLo and direction == 1 ) then rpm = rpm - incrementRpm end if (rpm>thrRpmHi) then direction = 1 elseif (rpm<thrRpmLo) then direction = 0 end end
Simulating Laps
