RaceCapture DashWare Guide
Record and save data on RCP
- Open the log file in Excel, go to Data > Convert Text to Columns > Use comma for the seperator
The Autosports Labs Data Profile provided with Dashware does not work. You can download my Race Capture Pro Data Profile and some RCP gauges and a project template here (please see the ReadMe.txt). My RCP Data Profile maps 40 Race Capture Pro data elements to Dashware Inputs. The RaceCapturePro.xml file is the data profile. This maps the RaceCapturePro data log file to the available Dashware inputs. These Dashware inputs is how the gauges get the appropriate data. This RaceCapturePro.xml mapping assumes you used the select box in Race Capture App when setting up your Race Capture Pro to select your input names using the out of box input names (ie, RPM, AFR, Brake, OilPress, OilTemp, TPS, EGT, etc). If you added or customized any of your RCP input names, you will either have to rename the column in Excel before importing into Dashware, or you will have to update the Calculators/Converters and Column Mappings in Dashware Data Profiles (best way). It also assumes you have cleaned up the column headers. I have mapped Brake in RCP to Brake Position in Dashware. If you are using Brake for Brake Pressure, you will have to change that mapping in Dashware.
To add RaceCapturePro.xml data profile to your system go to Project --> Data File(s) --> Add --> Edit Profiles... --> Add New Data Profile... --> and click on Open Data Profiles Directory. This should open the C:\Users\YourUsernameHere\Documents\DashWare\DataProfiles directory. Copy the RaceCapturePro.xml into that directory, then hit the Refresh button on the New Data Profile window, then hit cancel. You should now be able to select the RaceCapturePro data profile. If not, close the application and open it back up. It is a good idea to take a look at the mappings to see what data is mapped to which Dashware inputs. Note that PredTime is mapped to SCUBA->Dive Time Remaining (Mins).
If you need more info or would like to create your own Dashware Data Profile, please see Rowan Hicks excellent guide here. https://www.rowanhick.com/2016/01/07/racecapture-pro-dashware-win
Fix your video file if needed
