RaceCapture DashWare Guide
Record and save data on RCP
  1. Find the session(s) you want to use on your SD card.
  2. Open the log file in Excel, go to Data > Convert Text to Columns > Use comma for the separator
  3. Ensure that the 2nd column is of format text, otherwise it’s too large as a number
  4. For the 2nd column (“Utc”|”ms”|0|0|1), make a new column and subtract the first value in the first entry from every item, divide this by 1000 to get back to seconds
  5. For all of the headings, take the format of “AccelX”|”G”|-333.0|333.0|25 and change to “AccelX” this is super important as it will lead to no amount of frustration if your column headings change in subsequent data logs
  6. Get rid of any rows that don’t have a valid latitude and longitude
  7. Export the resulting file as .CSV
To add the RaceCapturePro.xml data profile to your system in Dashware go to Project --> Data File(s) --> Add --> Edit Profiles... --> Add New Data Profile... --> and click on Open Data Profiles Directory. This should open the C:\Users\YourUsernameHere\Documents\DashWare\DataProfiles directory. Copy the RaceCapturePro.xml into that directory, then hit the Refresh button on the New Data Profile window, then hit cancel. You should now be able to select the RaceCapturePro data profile. If not, close the application and open it back up. It is a good idea to take a look at the mappings to see what data is mapped to which Dashware inputs. Note that PredTime is mapped to SCUBA->Dive Time Remaining (Mins). I have mapped Brake in RCP to Brake Position in Dashware. If you are using Brake for Brake Pressure, you will have to change that mapping in Dashware.
If you need more info or would like to create your own Dashware Data Profile, please see Step 3 of Rowan Hicks excellent guide here. https://www.rowanhick.com/2016/01/07/racecapture-pro-dashware-win
Fix your video file if needed
