RaceCapture DashWare Guide
Record and save data on RCP
  1. Find the session(s) you want to use on your SD card.
  2. Open the log file in Excel, go to Data > Convert Text to Columns > Use comma for the separator
  3. Ensure that the 2nd column is of format text, otherwise it’s too large as a number
  4. For the 2nd column (“Utc”|”ms”|0|0|1), make a new column and subtract the first value in the first entry from every item, divide this by 1000 to get back to seconds
  5. For all of the headings, take the format of “AccelX”|”G”|-333.0|333.0|25 and change to “AccelX” this is super important as it will lead to no amount of frustration if your column headings change in subsequent data logs
  6. Get rid of any rows that don’t have a valid latitude and longitude
  7. Export the resulting file as .CSV
If you need more info or would like to create your own Dashware Data Profile, please see Step 3 of Rowan Hicks excellent guide here. https://www.rowanhick.com/2016/01/07/racecapture-pro-dashware-win
Fix your video file if needed
