RaceCapture-Track MK2
Start it up
Plug it in
- Plug one end of the OBDII cable into the RaceCapture RJ45 port.
Mounting
Place the RaceCapture system on a level surface in your car, with the connectors facing forward and logo up. This is the factory orientation for the accelerometers and gyro.
Attach GPS
Locating Antenna
- Ideal: Mount the antenna on the roof of the vehicle, using the magnetic mount. Place the antenna with minimum 3 feet spacing from other transmitting antennas (car radios, cellular antennas, etc).
- Alternate Mounting: You can mount it on the dashboard in clear view of the sky, or on the rear parcel tray under the back window. Note, this may degrade your GPS performance vs. roof mounting.
Download the app
- Windows 10 and OSX: No drivers are needed for OSX or Windows 10.
- Windows XP, 7, 8: See the driver installation instructions below.
First Time Setup
Android
We recommend connecting with Bluetooth when using Android devices.
Connecting with Bluetooth
- Ensure RaceCapture is powered.
- Note: The default password is 1234 - you can change this later under Setup.
Connecting with WiFi
- Under Android settings, navigate to the WiFi section.
- Wait until you see the RaceCapture WiFi network.
- Select this network to connect.
- Note: No password is required for the initial connection - you can set a password for your WiFi network later under Setup.
iOS
- Under your iOS settings, navigate to the WiFi section.
Launching the first time Setup
Setup Mode
Explanation of buttons
<img src="
" width="640"/>
Enabling Telemetry
Notes about Android devices
Analysis
Selecting time vs distance
RaceRender
Applying Decals
Extended Setup Guide
Alternative ways to power
USB
Custom Cable
You can build a custom cable for power and CAN bus using a standard CAT-5 ethernet cable with an RJ45 connector. Wire up using the following diagram.
- Note: OBDII is enabled by default on CAN1; CAN2 is recommended for secondary sensor networks.
| Connection | RaceCapture/Track MK2 (RJ45 cable) |
| +12v | Brown |
| Ground | Orange/White |
| CAN 1 High | Orange |
| CAN 1 Low | Green/White |
| CAN 2 High | Blue |
| CAN 2 Low | Blue/White |
Integrating AnalogX
Suggested parts
- RJ45 Splitter "Hub" shaped
Splice the following connections between AnalogX and an RJ45 cable with one end cut, forming a pigtail.
AnalogX will receive power from the OBDII cable, and provide data to RaceCapture via CAN2.
| Connection | AnalogX connection | RaceCapture/Pro or RaceCapture/Track MK2 (RJ45 cable) |
| +12v | Red | Brown |
| Ground | Blue | Orange/White |
| CAN 2 High | Black | Blue |
| CAN 2 Low | Orange | Blue/White |
Enabling the CAN preset and calibrating sensors
Setting CAN baud rate
The default baud rate for AnalogX is 500K. If you still have it set to the default, ensure this is set under the CAN bus settings.
Selecting the AnalogX preset
Steps to recover:
- Connect RaceCapture via USB
