RaceCapture-Track
Start it up
Plug it in
Download the app
- Google Play
- Amazon App Store
RaceCapture software on Windows / OSX
- Windows 10 and OSX: No drivers are needed for OSX or Windows 10.
- Windows XP, 7, 8: See the driver installation instructions below.
Setup Mode
Explanation of buttons
<img src="
" width="640"/>
Enabling Telemetry
Notes about Android devices
Logs
Analysis Mode
Selecting time vs distance
RaceRender
Updating Firmware
Firmware update is performed using a Windows or OSX machine via the USB interface. Be sure you have the RaceCapture software installed on your computer before proceeding.
- Download the latest firmware for your system, making note of the hardware version. Ensure it is RaceCapture/Track MK1
- Unzip this firmware archive to a location on your computer.
- Connect your RaceCapture system to your Windows or OSX computer using the included USB cable.
- Run the RaceCapture app, and confirm that it is connected.
- Navigate to the Setup view
- Save your current configuration. The firmware upgrade may reset your RaceCapture device to a factory default.
- Press Read to read the current configuration and then press Save to save it to a file.
- Select the Firmware section in the left menu.
- Press the Update Firmware Button
- Browse to the unzipped firmware from the first step. Select the file ending with ".ihex" - (example RaceCapture_Track_2.15.1.ihex) and press Open
- The firmware will begin updating - watch for the progress to go 0-100%.
- Restore your saved configuration by pressing the Open button, selecting your saved configuration, and then Write it to your RaceCapture system.
- Confirm your firmware is updated by viewing the firmware version in the upper right corner of the RaceCapture app, after connecting.
More
Alternative ways to power
USB
Custom Cable
| Connection | RaceCapture (RJ45 cable) |
| +12v | Brown |
| Ground | Orange/White |
| CAN 1 High | Orange |
| CAN 1 Low | Green/White |
- You forgot the password you set for RaceCapture's Access Point
- You just accidentally messed something up
Steps to recover:
- Connect RaceCapture via USB
- Under Setup, adjust the WiFi settings as needed
