RaceCapturePro Lua Scripting Examples
API Reference
OBDII tricks
Clear current trouble codes
setTickRate(1) count = 0 function onTick() checkClearCodes() end function checkClearCodes() if count % 10 == 0 then print('clearing codes') txCAN(0, 0x7df, 0, {1,4}) end end
--This example queries for and reads the first available DTC, if present. setTickRate(1) --P=Powertrain, C=Chassis, B=Body, U=Network prefixes = {'P','C','B','U'} digits = {'0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F'} function toDigit(v) return digits[v+1] end function printDTC(data) local dtc local a = data[3] local b = data[4] local prefix = prefixes[bit.band(bit.rshift(a, 6), 0x03) + 1] local c2 = bit.band(bit.rshift(a, 4), 0x03) local c3 = bit.band(a, 0x0f) local c4 = bit.band(bit.rshift(b, 4), 0x0F) local c5 = bit.band(b, 0x0F) local code = prefix ..toDigit(c2) ..toDigit(c3) ..toDigit(c4) ..toDigit(c5) println('Found DTC: ' ..code) end function printRawDTC(data) print('Raw DTC bytes: ') --print the remaining 6 bytes, --this raw data holds the trouble codes for i=1, #data do print(' ' ..data[i]) end println('') end function checkDTCResponse() local attempts = 0 while attempts < 50 do local id,ext, data = rxCAN(0, 10) if id ~= nil and ext == 0 and id == 0x7e8 then if data[2] == 0x43 then if data[1] > 2 then printRawDTC(data) printDTC(data) else println('No DTC Found') end return end end attempts = attempts + 1 end end function sendCheckDTC() println('Sending check DTC') txCAN(0, 0x7df, 0, {1,3}) end function onTick() sendCheckDTC() checkDTCResponse() end
Data filtering
Simple RPM Filter
Automatic logging control
function onTick() if getAnalog(8) > 13 then startLogging() else stopLogging() end end
--The real analog channel should be named --something other than FuelLevel fuel2Id = addChannel("FuelLevel", 10, 0, 0,100,"%") --change this to make a bigger averaging window maxAvg = 600 --600 = 20 seconds averaging at 30Hz tick rate --do not change fuelAvg={} fuel2Index = 1 function updateFuelAvg(value) local i if #fuelAvg == 0 then --initialize averaging table for i = 1, maxAvg do fuelAvg[i]=0 end end fuelAvg[fuel2Index] = value fuel2Index = fuel2Index + 1 if fuel2Index > maxAvg then fuel2Index = 1 end local sum = 0 for i = 1, #fuelAvg do sum = sum + fuelAvg[i] end setChannel(fuel2Id, sum / maxAvg) end setTickRate(30) function onTick() updateFuelAvg(getAnalog(0)) end
--10Hz update setTickRate(10) --Create channel: "SensorAvg" --Sample rate: 10Hz --Logging precision: 2 decimal points --min/max: 0/5 --Units: "Volts" avgId = addChannel("SensorAvg", 10, 2, 0, 5, "Volts") function onTick() local a1 = getAnalog(0) local a2 = getAnalog(1) setChannel(avgId, (a1 + a2) / 2) end
Gear Calculation
setTickRate(30) --create gear channel gearId = addChannel("Gear", 10, 0, 0, 6) function onTick() -- calculate gear: tire diameter(cm), final gear ratio, individual gear ratios 1-6 local gear = calcGear(62.7, 3.45, 4.23, 2.52, 1.66, 1.22, 1.0, 0.8) if gear == nil then gear = 0 end setChannel(gearId,gear) end
Also available as a preset
Throttle Position Calculation
--Developed by Scott Barton of ProFormance Coaching for use by Autosport Labs Community MaxAccelG = 0.30 -- Look at your logs and see what your max acceleration is in 3rd or 4th gear. Note that full acceleration in 5th will not show 100% throttle. chThrottle = addChannel("vThrottle", 10, 0, 0, 100,'') function updatevThrottle() --AccelG = getChannel(LongAccel) --2.13 Firmware and up AccelG = getImu(0) --Prior to 2.13 Firmware TPS = (AccelG/MaxAccelG)*100 if TPS < 0 then TPS = 0 end TPS = math.abs(TPS) if TPS > 99 then TPS = 100 end setChannel(chThrottle, TPS) end --10Hz update setTickRate(10) function onTick() updatevThrottle() end
Brake Position Calculation
--Developed by Scott Barton of ProFormance Coaching for use by Autosport Labs Community MaxDecelG = 1.20 --Look at your logs and see what your maximum g-forces under straight line braking is and round down. chBrake = addChannel("vBrake", 10, 0, 0, 100, '') function updatevBrake() --BrakeG = getChannel(LongAccel) -- 2.13 Firmware and up BrakeG = getImu(0) --Prior to 2.13 Firmware --if ReverseAccel then BrakeG = BrakeG *-1 --BrakeG = -1.1 BrakePos = (BrakeG/MaxDecelG)*100 if BrakePos < 10 then BrakePos = 0 end BrakePos = math.abs(BrakePos) if BrakePos > 99 then BrakePos=100 end setChannel(chBrake, BrakePos) end --10Hz update setTickRate(10) function onTick() updatevBrake() end
maxRpmId = addChannel("MaxRPM", 10) maxRpm = 0 function rpmReset() local rpm = getTimerRpm(0) local clear = getGpio(0) if rpm > maxRpm then maxRpm = rpm setChannel(maxRpmId, maxRpm) end if clear == 0 then maxRpm = 0 setChannel(maxRpmId, maxRpm) end end function onTick() rpmReset() end
Alerts/Notifications
Create an over-rev marker
setTickRate(10) overRevId = addChannel("OverRev", 10) function onTick() local rpm = getTimerRpm(0) local overRev = 0 if rpm > 8000 then overRev = 1 end setChannel(overRevId, overRev) end
Given:
Track Max RPM / Value
or
Multi warning light
- Using PWM/Analog output
- Using GPIO in output mode
Given:
- RPM sensor on timer input 0
ProFormance Meter
setTickRate(25) sxSetConfig(1) yawThreshold = 25 --At what yaw rate do you want the oversteer alarm lights to trigger' Check normal max yaw on your Podium.live race summaries to get a better idea of what value you should use flipBrakeAccel = false --set to true if you have your RC mounted backwards maxGsumId = addChannel("MaxGsum", 25, 2, -2.0, 2.0) pctGsumMaxId = addChannel("PctMaxGsum", 25, 0, 0, 100) maxLatGId = addChannel("MaxLatG", 25, 2, -2.0, 2.0) maxBrakeGId = addChannel("MaxBrakeG", 25, 2, -2.0, 2.0) maxAccelGId = addChannel("MaxAccelG", 25, 2, -2.0, 2.0) maxYawId = addChannel("MaxYaw", 25, 0, 0, 180) --Can remove this once you get an idea of what your YawThreshold should be ProFormanceRatingId = addChannel("ProFormance", 25, 0, 9) maxGsum = .3 maxLatG = .2 maxBrakeG = .2 maxAccelG = .1 maxYaw = 1 currLatG = 0 longG = 0 lastLongG = 0 lastLatG = 0 ProFormanceRating=0 function updateGStats() local gsum = getChannel("Gsum") if gsum ~= nil and gsum > 0 then if gsum > maxGsum then maxGsum = gsum setChannel(maxGsumId, maxGsum) end setChannel(pctGsumMaxId, (gsum / maxGsum) * 100) end local latG = getChannel("AccelY") if latG ~= nil then latG = math.abs(latG) if latG > maxLatG then maxLatG = latG setChannel(maxLatGId, maxLatG) end end local currLongG = getChannel("AccelX") if currLongG ~= nil then if flipBrakeAccel then currLongG = currLongG*-1 end if currLongG>0 then if currLongG > maxBrakeG then maxBrakeG = currLongG setChannel(maxBrakeGId, maxBrakeG) end elseif currLongG<0 then currLongG = math.abs(currLongG) if currLongG>maxAccelG then maxAccelG = currLongG setChannel(maxAccelGId, maxAccelG) end end end --Can remove this Yaw section once you get an idea of what your YawThreshold should be local Yaw = getChannel("Yaw") if Yaw ~= nil then Yaw = math.abs(Yaw) if Yaw > maxYaw then maxYaw = Yaw setChannel(maxYawId, maxYaw) end end end --Light up the side ShiftX lights in case of an Oversteer event function alertYaw(Yaw) if Yaw >= yawThreshold+20 then sxSetLed(7,2,255,255,255,9) elseif Yaw >= yawThreshold+10 then sxSetLed(7,2,255,255,255,5) elseif Yaw >= yawThreshold then sxSetLed(7,2,255,255,255,3) else sxSetLed(7,2,0,0,0,0) end end --resets all the ShiftX lights to off function resetSxLeds() sxSetLed(0,0,0,0,0,0) end --Calculate how much grip they are using and how much is left function getProFormanceRating(driverLevel) --driverLevel: 1=Advanced, 2=Pro local cLatG = getChannel("AccelY") if cLatG ~= nil then currLatG = math.abs(cLatG) end local cLongG = getChannel("AccelX") if cLongG ~= nil then longG = cLongG if flipBrakeAccel then longG = longG*-1 end end local BrakeAccel = "Braking" local maxLongG = maxBrakeG --may not want to do this --if longG <= -0.01 then -- BrakeAccel = "Accelerating" -- maxLongG = maxAccelG --end local currLongG = math.abs(longG) local percLatGUsed = currLatG/maxLatG --How much of maxLatG (max cornering G's) are we actually using right now local percLongGUsed = currLongG/maxLongG ---How much of maxLongG (max Braking/Accel G's) are we actually using right now local percLatGAvail = 1-percLongGUsed --Given current braking/accel G's (currLongG), how much cornering (LatG's) could we be doing? local percLongGAvail = 1-percLatGUsed -- Given current cornering G's (currLatG), how much braking or accelerating (LongG's) could we be doing? local currTotalG = math.sqrt((currLatG^2)+(currLongG^2)) -- GSum local currCombinedG = currLatG+currLongG local totalLatGAvail = maxLatG - ((maxLatG-maxLongG)*percLongGUsed) local totalLongGAvail = maxLongG - ((maxLongG-maxLatG)*percLatGUsed) --Models on how much grip is available is based on typical Friction Circle plots for Advanced Drivers vs Pro Drivers. --Advanced drivers friction circle looks more like a triangle where currLatG+currLongG = maxGSum. --Professional driver's firction circle looks more like a sideways D where SQRT((currLatG^2)+(currLongG^2)) = maxGsum --example: If maxGSum of a car is 1G, an advanced driver would do .5G braking and .5G cornering. A pro driver in same car could do .7G braking and .7G cornering. --once a driver can consistently corner in the 8-9 ProFormance rating, they should use the Pro Driver setting local latGAvail = 0 local longGAvail = 0 if driverLevel==1 then --Advanced driver latGAvail = maxLatG*percLatGAvail longGAvail = maxLongG*percLongGAvail else --Pro Driver latGAvail = math.sqrt((totalLatGAvail^2)-(currLongG^2)) longGAvail = math.sqrt((totalLongGAvail^2)-(currLatG^2)) end local percGUsedLat if latGAvail <= 0 then percGUsedLat = 1 else percGUsedLat = currLatG/latGAvail end local totalGAvailLat = math.sqrt((currLongG^2)+(latGAvail^2)) local combinedGAvailLat = currLongG+latGAvail local percGUsedLong if longGAvail <= 0 then percGUsedLong = 1 else percGUsedLong = currLongG/longGAvail end local totalGAvailLong = math.sqrt((currLatG^2)+(longGAvail^2)) local combinedGAvailLong = currLatG+longGAvail --local AvgLatPotential = (percLatGUsed+percGUsedLat)/2 local TotalLatPot1 = percGUsedLong+(percLatGAvail*percGUsedLat) local TotalLatPot2 if totalGAvailLat <= 0 then TotalLatPot2 = 1 else TotalLatPot2 = currTotalG/totalGAvailLat end local TotalLatPot3 if combinedGAvailLat <= 0 then TotalLatPot3 = 1 else TotalLatPot3 = currCombinedG/combinedGAvailLat end local TotalLatPot4 = percGUsedLat+((1-percGUsedLat)*percLongGUsed) local avgTotLatPot = (TotalLatPot1+TotalLatPot2+TotalLatPot3+TotalLatPot4)/4 --local AvgLongPotential = (percLongGUsed+percGUsedLong)/2 local TotalLongPot1 = percGUsedLat+(percLongGAvail*percGUsedLong) local TotalLongPot2 if totalGAvailLong <= 0 then TotalLongPot2 = 1 else TotalLongPot2 = currTotalG/totalGAvailLong end local TotalLongPot3 if combinedGAvailLong <= 0 then TotalLongPot3 = 1 else TotalLongPot3 = currCombinedG/combinedGAvailLong end local TotalLongPot4 = percGUsedLong+((1-percGUsedLong)*percLatGUsed) local avgTotLongPot = (TotalLongPot1+TotalLongPot2+TotalLongPot3+TotalLongPot4)/4 if currLongG-lastLongG > currLatG-lastLatG then ProFormanceRating = math.floor(avgTotLongPot*10) else ProFormanceRating = math.floor(avgTotLatPot*10) end if ProFormanceRating<0 then ProFormanceRating=0 end if ProFormanceRating>9 then ProFormanceRating=9 end setChannel(ProFormanceRatingId, ProFormanceRating) lastLongG = currLongG lastLatG = currLatG return ProFormanceRating end --Show ProFormanceRating on ShiftX function showProFormanceSx(rating) local numLeds=7 --How many LEDs on the ShiftX do you want to use for the ProFormance meter. Default is 7; the 7 in the middle resetSxLeds() sxSetLed(0,numLeds,255,0,0,0) local percLeds = (.1*rating*(numLeds+1)) local greenLeds =math.floor(percLeds) if greenLeds>0 then sxSetLed(0,greenLeds,0,255,0,0) end if percLeds-greenLeds>0.61 then sxSetLed(greenLeds,1,100,100,0,2) end sxSetDisplay(0,rating) end function onTick() collectgarbage() resetSxLeds() updateGStats() --ProFormance driver level: 1=Advanced, 2=Pro local driverLevel = 1 ProFormanceRating = getProFormanceRating(driverLevel) showProFormanceSx(ProFormanceRating)--Show ProFormance Rating on ShiftX if getChannel("Yaw")~=nil then Yaw = getChannel("Yaw") end if math.abs(Yaw)>yawThreshold-5 then alertYaw(math.abs(Yaw)) end end
CAN bus scripts
setTickRate(30) function onTick() id, ext, data = rxCAN(0) if (id ~= nil) then txCAN(1, id, ext, data) end end
Given:
- CAN1 channel is used
Given:
Given:
- Sets tick rate to 10Hz
CAN bus loopback test
Wiring / Setup
-- CAN loopback test -- * Wire CAN1 high -> CAN2 high and CAN 1 low -> CAN 2 low -- * Ensure baud rate is identical for both CAN1 and CAN2 can_id = 1234 count = 0 function onTick() count = count + 1 -- transmit a CAN message on CAN1 with count as the first byte local tx_result = txCAN(0, can_id, 0, {count}) println('transmit result ' ..tx_result) -- receive a CAN message on CAN2 local id, ext, data = rxCAN(1) if id == nil then println('No CAN message received!') else println('Got CAN message ID: ' ..id ..' data: ' ..data[1]) end end
Serial Port
Read a line of serial data
Demo Scripts
RPM Sweep
-- 05 Jan 2016 RPM demo -- F.Mirandola - B.Picasso -- This code will show a demo RPM sweep on RaceCapturePro thrRpmLo = 3000 --Low RPM threshold for change direction thrRpmHi = 10000 --Hi RPM threshold for change direction incrementRpm = 300 --Step between each RPM increment/decrement, will affect the speed, higher = faster -- Do not edit after this!! setTickRate(10) rpm = 0 direction = 0 rpmId = addChannel("RPM", 10, 0, 0, 10000) function onTick() setChannel(rpmId, rpm) if (rpm<=thrRpmHi and direction == 0 ) then rpm = rpm + incrementRpm elseif (rpm>=thrRpmLo and direction == 1 ) then rpm = rpm - incrementRpm end if (rpm>thrRpmHi) then direction = 1 elseif (rpm<thrRpmLo) then direction = 0 end end
Simulating Laps
