RaceCapture-Track
Start it up
Plug it in
Download the app
- Google Play
- Amazon App Store
RaceCapture software on Windows / OSX
- Windows 10 and OSX: No drivers are needed for OSX or Windows 10.
- Windows XP, 7, 8: See the driver installation instructions below.
LED status
- * 'Very fast green flash: Very rapid green flash indicates the unit is in bootloader mode, during firmware updates. If you see this when the the unit powers up and you cannot connect with the RaceCapture app, it usually means a failed firmware upgrade. You can resolve the issue by going through the firmware update process again.
- Blue : WiFi activity
- Red: Firmware error
Setup Mode
Explanation of buttons
<img src="
" width="640"/>
Enabling Telemetry
Notes about Android devices
Logs
Analysis Mode
Selecting time vs distance
RaceRender
Updating Firmware
More
Alternative ways to power
USB
Custom Cable
| Connection | RaceCapture (RJ45 cable) |
| +12v | Brown |
| Ground | Orange/White |
| CAN 1 High | Orange |
| CAN 1 Low | Green/White |
- You forgot the password you set for RaceCapture's Access Point
- You just accidentally messed something up
Steps to recover:
- Connect RaceCapture via USB
- Under Setup, adjust the WiFi settings as needed
