RaceCapturePro Lua Scripting Examples
API Reference
OBDII tricks
Clear current trouble codes
setTickRate(1)
count = 0
checkClearCodes()
function checkClearCodes()
if count % 10 == 0 then
print('clearing codes')
txCAN(0, 0x7df, 0, {1,4})
setTickRate(1)
prefixes = {'P','C','B','U'}
function toDigit(v)
return digits[v+1]
function printDTC(data)
local dtc
local a = data[3]
local b = data[4]
local c3 = bit.band(a, 0x0f)
local c5 = bit.band(b, 0x0F)
println('Found DTC: ' ..code)
function printRawDTC(data)
print('Raw DTC bytes: ')
println('')
function checkDTCResponse()
local attempts = 0
while attempts < 50 do
if data[2] == 0x43 then
if data[1] > 2 then
printRawDTC(data)
printDTC(data)
else
println('No DTC Found')
return
attempts = attempts + 1
function sendCheckDTC()
println('Sending check DTC')
txCAN(0, 0x7df, 0, {1,3})
sendCheckDTC()
checkDTCResponse()
Display OBDII Codes as a channel and allow driver to reset the OBDII Codes with a button
tickRate = 5
counter=0
OBDCodes = {'-1'}
currCode = 1
function clearOBDCodes()
for i=#OBDCodes, 1, -1 do
OBDCodes[i] = nil
OBDCodes[1] = '-1'
function addOBDCode(code)
local codeFound = false
for i=1, #OBDCodes do
if not codeFound then
OBDCodes[#OBDCodes+1] = code
function displayOBDCodes()
counter = counter+1
currCode = currCode+1
counter = 0
clearOBDCodes()
function toDigit(v)
return digits[v+1]
local dtc
local a = data[3]
local b = data[4]
addOBDCode(code)
code = prefix ..code
a = data[5]
b = data[6]
local d3 = bit.band(a, 0x0f)
local d5 = bit.band(b, 0x0F)
addOBDCode(code2)
code2 = prefix ..code2
a = data[7]
b = data[8]
local e3 = bit.band(a, 0x0f)
local e5 = bit.band(b, 0x0F)
addOBDCode(code3)
code3 = prefix ..code3
println('')
local attempts = 0
if data[1] > 2 then
printRawDTC(data)
printDTC(data)
else
--println('No DTC Found')
return
checkDTCResponse(1)
displayOBDCodes()
checkClearCodes(1)
Data filtering
Simple RPM Filter
--sample RPM at 10Hz
rpmLimit = 10000
rpm = 0
function doRPM()
local r = getTimerRpm(0)
if r < rpmLimit then
rpm = r
setChannel(rpmId, rpm)
doRPM()
Automatic logging control
if getGpsSpeed() > 10 then
startLogging()
else
stopLogging()
if getAnalog(8) > 13 then
startLogging()
else
stopLogging()
setTickRate(30)
local arm = getGpio(0)
local g = getAccel(1)
if arm == 0 then
stopLogging()
if arm == 1 and g < 0.1 then
startLogging()
maxAvg = 600
--do not change
fuelAvg={}
fuel2Index = 1
function updateFuelAvg(value)
local i
if #fuelAvg == 0 then
--initialize averaging table
fuelAvg[fuel2Index] = value
fuel2Index = fuel2Index + 1
local sum = 0
for i = 1, #fuelAvg do
sum = sum + fuelAvg[i]
setTickRate(30)
updateFuelAvg(getAnalog(0))
--10Hz update
--Create channel: "SensorAvg"
--Sample rate: 10Hz
--min/max: 0/5
--Units: "Volts"
local a1 = getAnalog(0)
local a2 = getAnalog(1)
Gear Calculation
setTickRate(30)
--create gear channel
setChannel(gearId,gear)
Also available as a preset
Throttle Position Calculation
MaxAccelG = 0.30 -- Look at your logs and see what your max acceleration is in 3rd or 4th gear. Note that full acceleration in 5th will not show 100% throttle.
function updatevThrottle()
TPS = (AccelG/MaxAccelG)*100
if TPS < 0 then TPS = 0 end
TPS = math.abs(TPS)
setChannel(chThrottle, TPS)
--10Hz update
updatevThrottle()
Brake Position Calculation
MaxDecelG = 1.20 --Look at your logs and see what your maximum g-forces under straight line braking is and round down.
function updatevBrake()
--if ReverseAccel then
BrakeG = BrakeG *-1
--BrakeG = -1.1
BrakePos = math.abs(BrakePos)
setChannel(chBrake, BrakePos)
--10Hz update
updatevBrake()
maxRpm = 0
function rpmReset()
local rpm = getTimerRpm(0)
local clear = getGpio(0)
if rpm > maxRpm then
maxRpm = rpm
setChannel(maxRpmId, maxRpm)
if clear == 0 then
maxRpm = 0
rpmReset()
Alerts/Notifications
Create an over-rev marker
Given:
local rpm = getChannel("RPM")
Create an Impact marker
if gsum ~= nil and gsum > 2.0 then --Assumes anything over 2.0G's is an impact. Change to suit your needs.
function updateDiffSwitch()
if diffTemp ~=nil and diffTemp > 180 then --update temp to turn on at
setGpio(2,1)
setGpio(2,0) --Uses GPIO3 for output. Increase SampleRate or TickRate if it isn't turning on
Given:
--onTick() is called at 10Hz
rpmThreshold = 2000
lowOilPressure = 15
local shockDriver = 0
shockDriver = 1
setGpio(0, shockDriver)
Track Max RPM / Value
maxRpm = 0
maxRpm = rpm
setGpio(0, 1)
else
setGpio(0, 0)
or
Multi warning light
- Using PWM/Analog output
- Using GPIO in output mode
Given:
- RPM sensor on timer input 0
ProFormance Meter
setTickRate(25)
sxSetConfig(1)
yawThreshold = 25 --At what yaw rate do you want the oversteer alarm lights to trigger' Check normal max yaw on your Podium.live race summaries to get a better idea of what value you should use
maxGsum = .3
maxLatG = .2
maxBrakeG = .2
maxAccelG = .1
currLatG = 0
longG = 0
lastLongG = 0
lastLatG = 0
function updateGStats()
if gsum > maxGsum then
maxGsum = gsum
if latG ~= nil then
latG = math.abs(latG)
if latG > maxLatG then
maxLatG = latG
if currLongG ~= nil then
if currLongG>0 then
if currLongG > maxBrakeG then
maxBrakeG = currLongG
elseif currLongG<0 then
if currLongG>maxAccelG then
maxAccelG = currLongG
function alertYaw(Yaw) --Light up the side ShiftX lights in case of an Oversteer event
sxSetLed(7,2,255,255,255,9)
sxSetLed(7,2,255,255,255,5)
sxSetLed(7,2,255,255,255,3)
else
sxSetLed(7,2,0,0,0,0)
sxSetLed(0,0,0,0,0,0)
local cLongG = getChannel("AccelX")
if cLongG ~= nil then
longG = cLongG
local BrakeAccel = "Braking"
local maxLongG = maxBrakeG
--may not want to do this
-- maxLongG = maxAccelG
--end
local latGAvail = 0
local longGAvail = 0
latGAvail = maxLatG*(1-(currLongG/maxLongG))
else --Pro Driver
local percGUsedLat
if latGAvail <= 0 then
percGUsedLat = 1
else
local percGUsedLong
if longGAvail <= 0 then
percGUsedLong = 1
else
local ProFormanceRating
local TotalPot2
TotalPot2 = 1
else
local TotalPot3
TotalPot3 = 1
else
else
local TotalPot2
TotalPot2 = 1
else
local TotalPot3
TotalPot3 = 1
else
lastLongG = currLongG
lastLatG = currLatG
return ProFormanceRating
resetSxLeds()
sxSetLed(0,numLeds,255,0,0,0)
sxSetDisplay(0,rating)
resetSxLeds()
updateGStats()
local driverLevel = 1
collectgarbage()
CAN bus scripts
setTickRate(30)
id, ext, data = rxCAN(0)
if (id ~= nil) then
txCAN(1, id, ext, data)
Given:
- CAN1 channel is used
local speed = getGpsSpeed()
local msg = {speed}
txCAN(0, 1234, 0, msg)
Given:
local tmp = getAnalog(0)
local msg = {tmp}
setTickRate(30) --30Hz
id, e, data = rxCAN(0)
print(id ..':')
for i=1,#data do
print(data[i] ..' ')
println('')
until id == nil
Given:
- Sets tick rate to 10Hz
id, ext, data = rxCAN(0, 100)
CAN bus loopback test
Wiring / Setup
-- CAN loopback test
can_id = 1234
count = 0
count = count + 1
if id == nil then
else
Serial Port
Read a line of serial data
value = readSer(4, 100)
if value ~= nil then
Demo Scripts
RPM Sweep
-- 05 Jan 2016 RPM demo
-- F.Mirandola - B.Picasso
thrRpmLo = 3000
thrRpmHi = 10000
incrementRpm = 300
-- Do not edit after this!!
rpm = 0
direction = 0
Simulating Laps
--use this script
et = 0 --ElapsedTime value
lt = 0 --LapTime value
pt = 0 --PredTime value
cl = 0 --CurrentLap value
lc = 0 --LapCount value
--completed a lap
if lc > 0 then
pt = targetTime + rnd
setChannel(ptid, pt)
et = et + 0.00166666667
setChannel(etid, et)
if et > targetTime + rnd then
lt = et
setChannel(ltid, lt)
et = 0
cl = cl + 1
setChannel(clid, cl)
if cl > 1 then
lc = lc + 1
setChannel(lcid, lc)
