RaceCapturePro Lua Scripting Examples
API Reference
OBDII tricks
Clear current trouble codes
setTickRate(1) count = 0 function onTick() checkClearCodes() end function checkClearCodes() if count % 10 == 0 then print('clearing codes') txCAN(0, 0x7df, 0, {1,4}) end end
--This example queries for and reads the first available DTC, if present. setTickRate(1) --P=Powertrain, C=Chassis, B=Body, U=Network prefixes = {'P','C','B','U'} digits = {'0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F'} function toDigit(v) return digits[v+1] end function printDTC(data) local dtc local a = data[3] local b = data[4] local prefix = prefixes[bit.band(bit.rshift(a, 6), 0x03) + 1] local c2 = bit.band(bit.rshift(a, 4), 0x03) local c3 = bit.band(a, 0x0f) local c4 = bit.band(bit.rshift(b, 4), 0x0F) local c5 = bit.band(b, 0x0F) local code = prefix ..toDigit(c2) ..toDigit(c3) ..toDigit(c4) ..toDigit(c5) println('Found DTC: ' ..code) end function printRawDTC(data) print('Raw DTC bytes: ') --print the remaining 6 bytes, --this raw data holds the trouble codes for i=1, #data do print(' ' ..data[i]) end println('') end function checkDTCResponse() local attempts = 0 while attempts < 50 do local id,ext, data = rxCAN(0, 10) if id ~= nil and ext == 0 and id == 0x7e8 then if data[2] == 0x43 then if data[1] > 2 then printRawDTC(data) printDTC(data) else println('No DTC Found') end return end end attempts = attempts + 1 end end function sendCheckDTC() println('Sending check DTC') txCAN(0, 0x7df, 0, {1,3}) end function onTick() sendCheckDTC() checkDTCResponse() end
Display OBDII Codes as a channel and allow driver to reset the OBDII Codes with a button
--Modified by Scott Barton of ProFormance Coaching for Autosport Labs Community tickRate = 5 setTickRate(tickRate) counter=0 --P=Powertrain, C=Chassis, B=Body, U=Network prefixes = {'P','C','B','U'} digits = {'0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F'} OBDCodes = {'-1'} currCode = 1 addChannel("OBDIICodes", 1, 0) setChannel("OBDIICodes", -1)-- Some car manufactures send P0000 if there are no fault codes; therefore we will use -1 to know that no codes have been returned yet function clearOBDCodes() for i=#OBDCodes, 1, -1 do OBDCodes[i] = nil end OBDCodes[1] = '-1' end function addOBDCode(code) local codeFound = false for i=1, #OBDCodes do if OBDCodes[i] == '-1' or OBDCodes[i] == 0 then OBDCodes[i] = nil end if OBDCodes[i] == code then codeFound=true end end if not codeFound then OBDCodes[#OBDCodes+1] = code println(#OBDCodes ..' Total OBDII Codes Found So Far') end end function displayOBDCodes() counter = counter+1 if counter == 3*tickRate then --seconds since last update currCode = currCode+1 if currCode>#OBDCodes then currCode=1 end --println('Updating OBDII Code ' ..currCode ..' ' ..OBDCodes[currCode]) counter = 0 end setChannel("OBDIICodes", OBDCodes[currCode]) end function checkClearCodes(canChan) local ClrOBD = getChannel("ClearOBD ") --Must create an analog or GPIO channel called ClearOBD in your settings and map it to read 1 or higher when you push the external button wired to that input if ClrOBD ~= nil and ClrOBD > 0 then println('Clearing OBDII codes') txCAN(canChan, 0x7df, 0, {1,4}) --sends reset OBDII codes command to ECU clearOBDCodes() setChannel("OBDIICodes", -1) end end function toDigit(v) return digits[v+1] end function printDTC(data) local dtc local a = data[3] local b = data[4] local prefix = prefixes[bit.band(bit.rshift(a, 6), 0x03) + 1] local c2 = bit.band(bit.rshift(a, 4), 0x03) local c3 = bit.band(a, 0x0f) local c4 = bit.band(bit.rshift(b, 4), 0x0F) local c5 = bit.band(b, 0x0F) local code = toDigit(c2) ..toDigit(c3) ..toDigit(c4) ..toDigit(c5) addOBDCode(code) --setChannel("OBDIICodes", code) code = prefix ..code println('Found DTC: ' ..code) a = data[5] b = data[6] local d2 = bit.band(bit.rshift(a, 4), 0x03) local d3 = bit.band(a, 0x0f) local d4 = bit.band(bit.rshift(b, 4), 0x0F) local d5 = bit.band(b, 0x0F) local code2 = toDigit(d2) ..toDigit(d3) ..toDigit(d4) ..toDigit(d5) if tonumber(code2) ~= nil and tonumber(code2)>1 then addOBDCode(code2) code2 = prefix ..code2 println('Found 2nd DTC: ' ..code2) end a = data[7] b = data[8] local e2 = bit.band(bit.rshift(a, 4), 0x03) local e3 = bit.band(a, 0x0f) local e4 = bit.band(bit.rshift(b, 4), 0x0F) local e5 = bit.band(b, 0x0F) local code3 = toDigit(e2) ..toDigit(e3) ..toDigit(e4) ..toDigit(e5) if tonumber(code3) ~= nil and tonumber(code3)>1 then addOBDCode(code3) code3 = prefix ..code3 println('Found 3rd DTC: ' ..code3) end end function printRawDTC(data) print('Raw DTC bytes: ') --print the remaining 6 bytes, --this raw data holds the trouble codes for i=1, #data do print(' ' ..data[i]) end println('') end function checkDTCResponse(canChan) local attempts = 0 while attempts < 50 do local id,ext, data = rxCAN(canChan, 10) if id ~= nil and ext == 0 and id == 0x7e8 then if data[2] == 0x43 then if data[1] > 2 then printRawDTC(data) printDTC(data) else --println('No DTC Found') end return end end attempts = attempts + 1 end end function sendCheckDTC(canChan) --println('Sending check DTC') txCAN(canChan, 0x7df, 0, {1,3}) end function onTick() sendCheckDTC(1) --0=OBDII is on CAN Channel 1; 1=OBD is on CAN Channel 2 checkDTCResponse(1) displayOBDCodes() checkClearCodes(1) end
Data filtering
Simple RPM Filter
Automatic logging control
function onTick() if getAnalog(8) > 13 then startLogging() else stopLogging() end end
--The real analog channel should be named --something other than FuelLevel fuel2Id = addChannel("FuelLevel", 10, 0, 0,100,"%") --change this to make a bigger averaging window maxAvg = 600 --600 = 20 seconds averaging at 30Hz tick rate --do not change fuelAvg={} fuel2Index = 1 function updateFuelAvg(value) local i if #fuelAvg == 0 then --initialize averaging table for i = 1, maxAvg do fuelAvg[i]=0 end end fuelAvg[fuel2Index] = value fuel2Index = fuel2Index + 1 if fuel2Index > maxAvg then fuel2Index = 1 end local sum = 0 for i = 1, #fuelAvg do sum = sum + fuelAvg[i] end setChannel(fuel2Id, sum / maxAvg) end setTickRate(30) function onTick() updateFuelAvg(getAnalog(0)) end
--10Hz update setTickRate(10) --Create channel: "SensorAvg" --Sample rate: 10Hz --Logging precision: 2 decimal points --min/max: 0/5 --Units: "Volts" avgId = addChannel("SensorAvg", 10, 2, 0, 5, "Volts") function onTick() local a1 = getAnalog(0) local a2 = getAnalog(1) setChannel(avgId, (a1 + a2) / 2) end
Gear Calculation
setTickRate(30) --create gear channel gearId = addChannel("Gear", 10, 0, 0, 6) function onTick() -- calculate gear: tire diameter(cm), final gear ratio, individual gear ratios 1-6 local gear = calcGear(62.7, 3.45, 4.23, 2.52, 1.66, 1.22, 1.0, 0.8) if gear == nil then gear = 0 end setChannel(gearId,gear) end
Also available as a preset
Throttle Position Calculation
--Developed by Scott Barton of ProFormance Coaching for use by Autosport Labs Community MaxAccelG = 0.30 -- Look at your logs and see what your max acceleration is in 3rd or 4th gear. Note that full acceleration in 5th will not show 100% throttle. chThrottle = addChannel("vThrottle", 10, 0, 0, 100,'') function updatevThrottle() --AccelG = getChannel(LongAccel) --2.13 Firmware and up AccelG = getImu(0) --Prior to 2.13 Firmware TPS = (AccelG/MaxAccelG)*100 if TPS < 0 then TPS = 0 end TPS = math.abs(TPS) if TPS > 99 then TPS = 100 end setChannel(chThrottle, TPS) end --10Hz update setTickRate(10) function onTick() updatevThrottle() end
Brake Position Calculation
--Developed by Scott Barton of ProFormance Coaching for use by Autosport Labs Community MaxDecelG = 1.20 --Look at your logs and see what your maximum g-forces under straight line braking is and round down. chBrake = addChannel("vBrake", 10, 0, 0, 100, '') function updatevBrake() --BrakeG = getChannel(LongAccel) -- 2.13 Firmware and up BrakeG = getImu(0) --Prior to 2.13 Firmware --if ReverseAccel then BrakeG = BrakeG *-1 --BrakeG = -1.1 BrakePos = (BrakeG/MaxDecelG)*100 if BrakePos < 10 then BrakePos = 0 end BrakePos = math.abs(BrakePos) if BrakePos > 99 then BrakePos=100 end setChannel(chBrake, BrakePos) end --10Hz update setTickRate(10) function onTick() updatevBrake() end
maxRpmId = addChannel("MaxRPM", 10) maxRpm = 0 function rpmReset() local rpm = getTimerRpm(0) local clear = getGpio(0) if rpm > maxRpm then maxRpm = rpm setChannel(maxRpmId, maxRpm) end if clear == 0 then maxRpm = 0 setChannel(maxRpmId, maxRpm) end end function onTick() rpmReset() end
Alerts/Notifications
Create an over-rev marker
Given:
setTickRate(10) overRevId = addChannel("OverRev", 10) function onTick() local rpm = getChannel("RPM") if rpm ~= nil and rpm > 8000 then setChannel(overRevId, getLapCount()) end
Create an Impact marker
setTickRate(10) impactId = addChannel("Impact", 10) function onTick() local gsum = getChannel("Gsum") if gsum ~= nil and gsum > 2.0 then --Assumes anything over 2.0G's is an impact. Change to suit your needs. setChannel(impactId, getLapCount()) end end
function updateDiffSwitch() local diffTemp = getChannel("DiffTemp") --Change to your temperature channel name if diffTemp ~=nil and diffTemp > 180 then --update temp to turn on at setGpio(2,1) elseif diffTemp ~=nil and diffTemp < 160 then --update temp to turn off at setGpio(2,0) --Uses GPIO3 for output. Increase SampleRate or TickRate if it isn't turning on end end
Given:
Track Max RPM / Value
or
Multi warning light
- Using PWM/Analog output
- Using GPIO in output mode
Given:
- RPM sensor on timer input 0
ProFormance Meter
setTickRate(25) sxSetConfig(1) yawThreshold = 25 --At what yaw rate do you want the oversteer alarm lights to trigger' Check normal max yaw on your Podium.live race summaries to get a better idea of what value you should use maxGsumId = addChannel("MaxGsum", 25, 2, -2.0, 2.0) pctGsumMaxId = addChannel("PctMaxGsum", 25, 0, 0, 100) maxLatGId = addChannel("MaxLatG", 25, 2, -2.0, 2.0) maxBrakeGId = addChannel("MaxBrakeG", 25, 2, -2.0, 2.0) maxAccelGId = addChannel("MaxAccelG", 25, 2, -2.0, 2.0) ProFormanceRatingId = addChannel("ProFormance", 25, 0, 9) maxGsum = .3 maxLatG = .2 maxBrakeG = .2 maxAccelG = .1 currLatG = 0 longG = 0 lastLongG = 0 lastLatG = 0 function updateGStats() local gsum = getChannel("Gsum") if gsum ~= nil and gsum > 0 then if gsum > maxGsum then maxGsum = gsum setChannel(maxGsumId, maxGsum) end setChannel(pctGsumMaxId, (gsum / maxGsum) * 100) end local latG = getChannel("AccelY") if latG ~= nil then latG = math.abs(latG) if latG > maxLatG then maxLatG = latG setChannel(maxLatGId, maxLatG) end end local currLongG = getChannel("AccelX") if currLongG ~= nil then if currLongG>0 then if currLongG > maxBrakeG then maxBrakeG = currLongG setChannel(maxBrakeGId, maxBrakeG) end elseif currLongG<0 then currLongG = math.abs(currLongG) if currLongG>maxAccelG then maxAccelG = currLongG setChannel(maxAccelGId, maxAccelG) end end end end function alertYaw(Yaw) --Light up the side ShiftX lights in case of an Oversteer event if Yaw >= yawThreshold+20 then sxSetLed(7,2,255,255,255,9) elseif Yaw >= yawThreshold+10 then sxSetLed(7,2,255,255,255,5) elseif Yaw >= yawThreshold then sxSetLed(7,2,255,255,255,3) else sxSetLed(7,2,0,0,0,0) end end function resetSxLeds() --resets all the ShiftX lights to off sxSetLed(0,0,0,0,0,0) end function getProFormanceRating(driverLevel) --Calculate how much grip they are using and how much is left --driverLevel: 1=Advanced, 2=Pro local cLatG = getChannel("AccelY") if cLatG ~= nil then currLatG = math.abs(cLatG) end local cLongG = getChannel("AccelX") if cLongG ~= nil then longG = cLongG end local BrakeAccel = "Braking" local maxLongG = maxBrakeG --may not want to do this --if longG <= -0.01 then --Calculate Accel G's seperate from Braking G's -- BrakeAccel = "Accelerating" -- maxLongG = maxAccelG --end local currLongG = math.abs(longG) local latGAvail = 0 local longGAvail = 0 if driverLevel==1 then --Advanced driver latGAvail = maxLatG*(1-(currLongG/maxLongG)) longGAvail = maxLongG*(1-(currLatG/maxLatG)) else --Pro Driver latGAvail = math.sqrt(((maxLatG - ((maxLatG-maxLongG)*(currLongG/maxLongG)))^2)-(currLongG^2)) longGAvail = math.sqrt(((maxLongG - ((maxLongG-maxLatG)*(currLatG/maxLatG)))^2)-(currLatG^2)) end local percGUsedLat if latGAvail <= 0 then percGUsedLat = 1 else percGUsedLat = currLatG/latGAvail end local percGUsedLong if longGAvail <= 0 then percGUsedLong = 1 else percGUsedLong = currLongG/longGAvail end local ProFormanceRating if currLongG-lastLongG > currLatG-lastLatG then local TotalPot2 if (math.sqrt((currLatG^2)+(longGAvail^2))) <= 0 then TotalPot2 = 1 else TotalPot2 = (math.sqrt((currLatG^2)+(currLongG^2)))/(math.sqrt((currLatG^2)+(longGAvail^2))) end local TotalPot3 if (currLatG+longGAvail) <= 0 then TotalPot3 = 1 else TotalPot3 = (currLatG+currLongG)/(currLatG+longGAvail) end local avgTotPot = (((percGUsedLat+((1-(currLatG/maxLatG))*percGUsedLong))*2)+TotalPot2+TotalPot3)/4 ProFormanceRating = math.floor(avgTotPot*10) else local TotalPot2 if (math.sqrt((currLongG^2)+(latGAvail^2))) <= 0 then TotalPot2 = 1 else TotalPot2 = (math.sqrt((currLatG^2)+(currLongG^2)))/(math.sqrt((currLongG^2)+(latGAvail^2))) end local TotalPot3 if (currLongG+latGAvail) <= 0 then TotalPot3 = 1 else TotalPot3 = (currLatG+currLongG)/(currLongG+latGAvail) end local avgTotPot = (((percGUsedLong+((1-(currLongG/maxLongG))*percGUsedLat))*2)+TotalPot2+TotalPot3)/4 ProFormanceRating = math.floor(avgTotPot*10) end if ProFormanceRating<0 then ProFormanceRating=0 end if ProFormanceRating>9 then ProFormanceRating=9 end setChannel(ProFormanceRatingId, ProFormanceRating) lastLongG = currLongG lastLatG = currLatG return ProFormanceRating end function showProFormanceSx(rating) --Show ProFormanceRating on ShiftX local numLeds=7 --How many LEDs on the ShiftX do you want to use for the ProFormance meter. Default is 7; the 7 in the middle resetSxLeds() sxSetLed(0,numLeds,255,0,0,0) local percLeds = (.1*rating*(numLeds+1)) local greenLeds =math.floor(percLeds) if greenLeds>0 then sxSetLed(0,greenLeds,0,255,0,0) end if percLeds-greenLeds>0.61 then sxSetLed(greenLeds,1,100,100,0,2) end sxSetDisplay(0,rating) end function onTick() resetSxLeds() updateGStats() --ProFormance driver level: 1=Advanced, 2=Pro local driverLevel = 1 local ProFormanceRating = getProFormanceRating(driverLevel) showProFormanceSx(ProFormanceRating)--Show ProFormance Rating on ShiftX if getChannel("Yaw")~=nil then Yaw = getChannel("Yaw") end if math.abs(Yaw)>yawThreshold-5 then alertYaw(math.abs(Yaw)) end collectgarbage() end
CAN bus scripts
setTickRate(30) function onTick() id, ext, data = rxCAN(0) if (id ~= nil) then txCAN(1, id, ext, data) end end
Given:
- CAN1 channel is used
Given:
Given:
- Sets tick rate to 10Hz
CAN bus loopback test
Wiring / Setup
-- CAN loopback test -- * Wire CAN1 high -> CAN2 high and CAN 1 low -> CAN 2 low -- * Ensure baud rate is identical for both CAN1 and CAN2 can_id = 1234 count = 0 function onTick() count = count + 1 -- transmit a CAN message on CAN1 with count as the first byte local tx_result = txCAN(0, can_id, 0, {count}) println('transmit result ' ..tx_result) -- receive a CAN message on CAN2 local id, ext, data = rxCAN(1) if id == nil then println('No CAN message received!') else println('Got CAN message ID: ' ..id ..' data: ' ..data[1]) end end
Integrate with RaceVoice via CAN
RaceVoice integrates with your data logger to audibly tell you info like high engine temp, low oil pressure, overrev, low battery, wheel lockup warnings as well as Pit to Car messages. It can also tell you things like rolling MPH at the end of a straight, max g-forces through a turn, lap segment delta, lap times, etc in order to be a more consistent and faster driver. You can find a list of Race Voice Features here. Take a look at this video for more info. {{#evu:https://www.youtube.com/watch?v=9aWVu1JyiZo}} Please note that Firmware 2.18 or greater is required for the Pit to Car messaging to work with RaceVoice.
--Created by Scott Barton of ProFormance Coaching for Autosport Labs Community tickRate = 10 setTickRate(tickRate) TPS = 100 RPM = 0 Speed = 0 AccelY = 0 AccelX = 0 ECT = 0 OilP = 0 Volts = 0 BrakeP = 0 WheelSpdLF = 0 WheelSpdRF = 0 WheelSpdLR = 0 WheelSpdRR = 0 LapNum = 0 LapTime = 0 BestTime = 0 LapDelta = 0 Lat = 0 Long = 0 function split16(val) return bit.band(val, 0xFF), bit.band(bit.rshift(val,8), 0xFF) end function split32(val) return bit.band(val, 0xFF), bit.band(bit.rshift(val,8), 0xFF), bit.band(bit.rshift(val,16),0xFF),bit.band(bit.rshift(val,24),0xFF) end function txRVCANData(channel) local lTPS = getChannel('TPS') if lTPS ~= nil then TPS = lTPS end local TPS1, TPS2 = split16(TPS) local lRPM = getChannel('RPM') if lRPM ~= nil then RPM = lRPM end local RPM1, RPM2 = split16(RPM) local lSpeed = getChannel('Speed') if lSpeed ~= nil then Speed = lSpeed end local Speed1, Speed2 = split16(Speed) local lAccelX = getChannel('AccelX') if lAccelX ~= nil then AccelX = lAccelX end local AccelX1, AccelX2 = split16(AccelX*100) local lAccelY = getChannel('AccelY') if lAccelY ~= nil then AccelY = lAccelY end local AccelY1, AccelY2 = split16(AccelY*100) local lECT = getChannel('EngineTemp') if lECT ~= nil then ECT = lECT end local ECT1, ECT2 = split16(ECT) local lOilP = getChannel('OilPress') if lOilP ~= nil then OilP = lOilP end local OilP1, OilP2 = split16(OilP) local lVolts = getChannel('Battery') if lVolts ~= nil then Volts = lVolts end local Volts1, Volts2 = split16(Volts*10) local lBrakeP = getChannel('BrakeF') if lBrakeP ~= nil then BrakeP = lBrakeP end local BrakeP1, BrakeP2 = split16(BrakeP) local lWheelSpdLF = getChannel('WhlSpeedLF') if lWheelSpdLF ~= nil then WheelSpdLF = lWheelSpdLF end local WheelSpdLF1, WheelSpdLF2 = split16(WheelSpdLF) local lWheelSpdRF = getChannel('WhlSpeedRF') if lWheelSpdRF ~= nil then WheelSpdRF = lWheelSpdRF end local WheelSpdRF1, WheelSpdRF2 = split16(WheelSpdRF) local lWheelSpdLR = getChannel('WhlSpeedLR') if lWheelSpdLR ~= nil then WheelSpdLR = lWheelSpdLR end local WheelSpdLR1, WheelSpdLR2 = split16(WheelSpdLR) local lWheelSpdRR = getChannel('WhlSpeedRR') if lWheelSpdRR ~= nil then WheelSpdRR = lWheelSpdRR end local WheelSpdRR1, WheelSpdRR2 = split16(WheelSpdRR) local lLapNum = getChannel('CurrrentLap') if lLapNum ~= nil then LapNum = lLapNum end local LapNum1, LapNum2 = split16(LapNum) local lLapTime = getChannel('LapTime') if lLapTime ~= nil then LapTime = lLapTime end local LapTime1, LapTime2 = split16(LapTime*10000) local lBestTime = getChannel('Bestlap') if lBestTime ~= nil then BestTime = lBestTime end local BestTime1, BestTime2 = split16(BestTime*10000) local lLapDelta = getChannel('LapDelta') if lLapDelta ~= nil then LapDelta = lLapDelta end local LapDelt11, LapDelta2 = split16(LapDelta*1000) local lLat = getChannel('Latitude') if lLat ~= nil then Lat = lLat end local Lat1, Lat2, Lat3, Lat4 = split32(Lat*10000000) local lLong = getChannel('Longitude') if lLong ~= nil then Long = lLong end local Long1, Long2, Long3, Long4 = split32(Long*10000000) txCAN(channel, 0x50, 0, {TPS2, TPS1, RPM2, RPM1, Speed2, Speed1, BrakeP2, BrakeP1}) txCAN(channel, 0x53, 0, {AccelX2, AccelX1, AccelY2, AccelY1}) txCAN(channel, 0x55, 0, {ECT2, ECT1, OilP2, OilP1, Volts2, Volts1}) txCAN(channel, 0x5A, 0, {LapNum2, LapNum1, LapTime2, LapTime1, BestTime2, BestTime1, LapDelta2, LapDelta1}) txCAN(channel, 0x56, 0, {Lat4, Lat3, Lat2, Lat1, Long4, Long3, Long2, Long1}) txCAN(channel, 0x51, 0, {WheelSpdLF2, WheelSpdLF1, WheelSpdRF2, WheelSpdRF1, WheelSpdLR2, WheelSpdLR1, WheelSpdRR2, WheelSpdRR1}) end function onTick() txRVCANData(1) --0=CAN Channel 1; 1=CAN Channel 2 collectgarbage() end
Serial Port
Read a line of serial data
Demo Scripts
RPM Sweep
-- 05 Jan 2016 RPM demo -- F.Mirandola - B.Picasso -- This code will show a demo RPM sweep on RaceCapturePro thrRpmLo = 3000 --Low RPM threshold for change direction thrRpmHi = 10000 --Hi RPM threshold for change direction incrementRpm = 300 --Step between each RPM increment/decrement, will affect the speed, higher = faster -- Do not edit after this!! setTickRate(10) rpm = 0 direction = 0 rpmId = addChannel("RPM", 10, 0, 0, 10000) function onTick() setChannel(rpmId, rpm) if (rpm<=thrRpmHi and direction == 0 ) then rpm = rpm + incrementRpm elseif (rpm>=thrRpmLo and direction == 1 ) then rpm = rpm - incrementRpm end if (rpm>thrRpmHi) then direction = 1 elseif (rpm<thrRpmLo) then direction = 0 end end
Simulating Laps
