Remote Coaching with Race Capture
Revision as of 04:25, 23 May 2020 by Sbarton (talk | contribs)
Initial Setup
Race Capture/Track Setup
  • Go to YouTube and sign in.
  • Download this File:Yi4KAutoStream.zip and copy the contents of the unzipped files onto a micro SD card. (note GB size does not matter. you cannot live stream and record video to SD card at same time)
