Remote Coaching with Race Capture
Revision as of 12:32, 23 May 2020 by Sbarton (talk | contribs)
Initial Setup
Race Capture/Track Setup
  • Go to YouTube and sign in.
Yi 4K Setup for Best Video
  • Update Firmware
  • Download this File:Yi4KAutoStream.zip and copy the contents of the unzipped files onto a micro SD card. (note GB size does not matter. you cannot live stream and record video to SD card at same time)
4G WiFi Hotspot notes
Event Setup
Charge hotspot and camera and mail out equipment
  • Race Capture/Track
  • Yi 4K Camera
  • 4G WiFi Hotspot (ensure there is enough data left on plan. 720p streaming uses 0.5GB/hr)
  • Camera mounting equipment
  • USB Charger and all 3 cables
  • Velcro
