Remote Coaching with Race Capture
- Autosport Labs Race Capture/Track ($299)
- Yi 4K Action Camera ($100-$200) (Must be Yi 4K, not Yi 4K+ or Yi Lite)
- MicroSD card ($6)
- 4G Hotspot with ~10GB/mo unrestricted/unthrottled data- Contact Eric Kaul at Verizon for the Motorsports/HPDE discount.
- 3 Port Smart USB car charger ($10)
- (2) 6' micro USB cables ($5)
- 2" wide Velcro ($19)
- Android or iOS cellphone with Race Capture app installed on it
- Bluetooth cellphone headset ($30)
Initial Setup
Race Capture/Track Setup
- Stick hook Velcro to bottom of Race Capture/Track
- For more info, see YouTube's instructions
- Fill out the info for a New stream and click Create Stream (you may want to change the privacy from Public to Unlisted or Private)
- Once the stream is created, turn on Enable Auto-start and copy the Stream URL and your Stream Key
Yi 4K Setup for Best Video
- Update Firmware
- Download this File:Yi4KAutoStream.zip and copy the contents of the unzipped files onto a micro SD card. (note GB size does not matter. you cannot live stream and record video to SD card at same time)
- Edit the rtmp_info.conf file:
- Replace YOUR_SSID_HERE with the SSID Name of your WiFi Hotspot. (Push the button on the Hotspot to get info)
- Replace YOUR_WIFI_PASSWORD_HERE with the password to your Hotspot (Push the button on the Hotspot to get info)
- Note: You may want to change the SSID and Password on your Hotspot before doing this. See the documentation that came with your hotspot for information on how to do this.
- Replace YOUR_RTMP_URL_HERE with your full YouTube Stream URL including the StreamID appended to it. It should look like rtmp://a.rtmp.youtube.com/live2/abcd-efgh-ijkl-mnop-qrst (replace abcd-efgh-ijkl-mnop-qrst with your StreamKey and make sure there is a / after the live2)
- Save the file and insert the MicroSD card into the Yi 4k and that's it. Whenever someone powers on your Yi 4K camera and hits the record button, it will automatically start streaming to your YouTube channel (assuming your Hotspot is powered on and nearby).
4G WiFi Hotspot notes
- 720p video streaming will use about 0.5GB/hr. Assume you will need 1-2GB per day depending on how good your client is about turning off the camera right away after a session.
- If they forget to turn off the camera after a session it will consume a lot of extra data which can be expensive. You may want to give them an allotment per day and charge them if they go over.
- If you already have a wireless account from a major carrier, you can usually add an hotspot fairly cheap.
- You can purchase new and used WiFi hotspots a lot cheaper on eBay than buying retail. Just make sure they aren't several years old.
- Be careful using so called Unlimited Plans. These plans are not good for streaming video, because after a certain point they throttle the bandwidth. Streaming video requires high bandwidth, and if they throttle your bandwidth, your video will be unusable.
- A 10GB/mo data plan should allow you to do (4) two-day weekends a month, assuming an average of around 2 hours of track time/video per day.
- You can get a Verizon Business plan with 22GB of data for $45/mo per device. Contact Eric Kaul at Verizon for details and discounts for motorsports members.
Event Setup
Charge hotspot and camera and mail out equipment
- Race Capture/Track
- Yi 4K Camera
- 4G WiFi Hotspot (ensure there is enough data left on plan. 720p streaming uses ~0.5GB/hr)
- Camera mounting equipment
- USB Charger and all 3 cables
- Velcro
