Remote Coaching with Race Capture
- Autosport Labs Race Capture/Track ($299)
- Yi 4K Action Camera ($100-$200) (Must be Yi 4K, not Yi 4K+ or Yi Lite)
- MicroSD card ($6)
- 4G Hotspot with ~10GB/mo unrestricted/unthrottled data- Contact Eric Kaul at Verizon for the Motorsports/HPDE discount.
- 3 Port Smart USB car charger ($10)
- (2) 6' micro USB cables ($5)
- 2" wide Velcro ($19)
- Android or iOS cellphone with Race Capture app installed on it
- Bluetooth cellphone headset ($30)
Initial Setup
Race Capture/Track Setup
- Stick hook Velcro to bottom of Race Capture/Track
- For more info, see YouTube's instructions
- Fill out the info for a New stream and click Create Stream (you may want to change the privacy from Public to Unlisted or Private)
- Once the stream is created, turn on Enable Auto-start and copy the Stream URL and your Stream Key
Yi 4K Setup for Best Video
- Update Camera Firmware
- Download the latest Firmware for YI 4K Action Camera
- Save the file to the MicroSD card and change the name to firmware.bin
- Insert the SD card into the camera and power it on. Follow instructions on the screen.
- Delete firmware.bin file when done.
- Power On Camera and go into settings by clicking the gear icon bottom right
- Use the following Video Settings:
- Resolution: 1080/60
- Field of View: Wide
- Metering Mode: Average
- Video Quality: High
- WB: Auto
- Click the gear icon on left side to go into Camera Settings:
- Go into Wifi settings:
- Set WiFi Frequency to 2.4G (or 5G if your Hotspot is set to only do 5G)
- Turn off WiFi (the script will automatically turn it on)
- Go into SD Card settings and do SD Card Format
- Default Camera Mode: Video
- Brightness: High
- Beeps: High
- Mic: Low
- Sound Effect: Wind
- Video Standard: NTSC
- In Advanced set:
- Screen Auto Lock: 60s
- Auto Power Off: 10Min
- Set Date and Time
- Battery percentage: On
- Download this File:Yi4KAutoStream.zip and copy the contents of the unzipped files onto the micro SD card. (note GB size does not matter. you cannot live stream and record video to SD card at same time)
- Edit the rtmp_info.conf file:
- Replace YOUR_SSID_HERE with the SSID Name of your WiFi Hotspot. (Push the button on the Hotspot to get info)
- Replace YOUR_WIFI_PASSWORD_HERE with the password to your Hotspot (Push the button on the Hotspot to get info)
- Note: You may want to change the SSID and Password on your Hotspot before doing this. See the documentation that came with your hotspot for information on how to do this.
- Replace YOUR_RTMP_URL_HERE with your full YouTube Stream URL including the StreamID appended to it. It should look like rtmp://a.rtmp.youtube.com/live2/abcd-efgh-ijkl-mnop-qrst (replace abcd-efgh-ijkl-mnop-qrst with your StreamKey and make sure there is a / after the live2)
- Save the file and insert the MicroSD card into the Yi 4k and that's it. Whenever someone powers on your Yi 4K camera and hits the record button, it will automatically start streaming to your YouTube channel (assuming your Hotspot is powered on and nearby).
4G WiFi Hotspot notes
- 720p video streaming will use about 0.5GB/hr. Assume you will need 1-2GB per day depending on how good your client is about turning off the camera right away after a session.
- If they forget to turn off the camera after a session it will consume a lot of extra data which can be expensive. You may want to give them an allotment per day and charge them if they go over.
- If you already have a wireless account from a major carrier, you can usually add an hotspot fairly cheap.
- You can purchase new and used WiFi hotspots a lot cheaper on eBay than buying retail. Just make sure they aren't several years old.
- Be careful using so called Unlimited Plans. These plans are not good for streaming video, because after a certain point they throttle the bandwidth. Streaming video requires high bandwidth, and if they throttle your bandwidth, your video will be unusable.
- A 10GB/mo data plan should allow you to do (4) two-day weekends a month, assuming an average of around 2 hours of track time/video per day.
- You can get a Verizon Business plan with 22GB of data for $45/mo per device. Contact Eric Kaul at Verizon for details and discounts for motorsports members.
- As mentioned above, you may want to change the default SSID and password for your hotspot. Consult the documentation for your particular hotspot. Pushing the button on the hotspot may give you information on how to change it.
- Stick hook velcro to bottom of hotspot
Event Setup
Podium.live Event Setup
- Login to Podium.live and go to Events and click on Create a new event and fill out details.
- Once the event is created on Podium.live, go into the event and click Add a device to this event
- For Video Embed field, enter https://www.youtube.com/embed/ followed by your YouTube video ID of your live stream.
- To get the Video ID of your live stream
- Login to YouTube
- Click on your profile pic on the top right, and click on YouTube Studio
- Click Videos on the left side navigation, and then Live under Channel videos.
- Click on the pencil icon next to your Remote Coaching live stream to go into the edit Details page.
- Under Video link on the right, copy the last portion of the URL that contains random letter/numbers. (ie. youtu.be/XpajniKJi_Y)This is your live stream VideoID.
- Your video embed URL should now look something like https://www.youtube.com/embed/XpajniKJi_Y
- You should be able to re-use t his video embed URL for all of your events, so save it somewhere to quickly re-use later.
- Paste your video embed URL into the Video Embed field on Podium.live device event page.
- See this wiki article for more info on how to Add video to Podium
After testing everything, charge hotspot and camera and then mail out equipment to client:
- Race Capture/Track with GPS Antenna and OBDII dongle
- Yi 4K Camera with MicroSD Card that has scripts
- 4G WiFi Hotspot (ensure there is enough data left on plan. 720p streaming uses ~0.5GB/hr)
- Camera mounting equipment
- USB Charger and all 3 cables
- Velcro to temporarily mount Race Capture/Track and Hotspot in car
Client Equipment Install and Setup
- Install latest Race Capture app for Android, FireOS, or iOS on their cellphone.
- Power on the RaceCapture/Track either with mini USB cable or OBDII dongle.
- Connect the phone to the RaceCapture/Track device either with Bluetooth (Android) or WiFi (iOS).
- Please see here for more info on how to Connect to the Race Capture/Track.
- Open Race Capture app on phone and do the following:
- Click Hamburger menu icon top left and go to Preferences
- Startup Screen: Dashboard
- Record Session: On
- Send telemetry: On (client's cell phone will send the data telemetry, not the hotspot. data telemetry uses minuscule amounts of data)
RaceCapture connection type: Set this to the type of connection you used to connect your phone to the RaceCapture/Track (probably Bluetooth for Android and WiFi for iOS).
- You may need to restart the Race Capture app for the connection type to take effect
- Once the Race Capture app has connected to the RaceCapture/Track, click the hamburger icon top left and click Setup
- Under Race Tracks:
- Turn on Automatic race track detection
- Click the Edit icon bottom right
- Click Update and wait for update to complete (may take a minute)
- Search and select the track you will be going to. If there are multiple configurations, make sure you only select the one you are going to. If you will be driving multiple configurations, select the entire track that has most/all the configurations.
- You do not need OBDII or CAN data from your car, but if you like, you can add it via the CAN Bus, CAN Mapping, and OBDII sections. Click Presets, then click Update select the Preset for your car or ECU if available.
- Please see the RaceCapture/Track Install instructions as well as the OBDII Instructions for more info on how to get CAN/OBDII data from your car.
