MegaJolt Lite Jr.
The Megajolt Lite Jr. (MJLJ) is a fully configurable, stand-alone ignition controller designed to control a Ford EDIS 4, 6 or 8 crank-fired ignition module. The result is a precision, digitally controlled distributorless ignition system.
Current Features
- Modern, easy to use, and customizable Windows-based configuration software
New with V2.8.x/V3.2.0
- TPS / Load axis calibration
- Improved user outputs with hysteresis
- Configuration software
Current Hardware
Version 4.x
Version 3.x
- Choosing between MAP or TPS
- Downloads
- Kit assembly guide
- Vehicle installation guide
Older hardware revisions
Version 2.x
Ancient History
