RaceCapture troubleshooting
  • Ensure the RaceCapture app is connected to RaceCapture
  • In the RaceCapture app press the top menu button and select 'System Status'
CAN bus troubleshooting
SD card logging
  • Ensure the card is installed with the label facing the top of the unit, metal contacts facing down
  • Freshly format the card to FAT32
  • Ensure the card is freshly formatted to FAT32 and empty
  • Try a different card
  • Use an SD card with a faster speed grade
  • Try a fresh format to reduce fragmentation
RaceCapture Log
To access the RaceCapture Log
  • Navigate to Setup and then select the Scripting screen (RaceCapture/Pro and RaceCapture/Apex) or the Logs screen (RaceCapture/Track)
  • The RaceCapture app will periodically query RaceCapture for log information. The log window will show messages from RaceCapture - scan these message for any errors. You can also copy the text in the log for future reference by pressing the Copy button.
Application Log
  • Navigate to the System Status page
  • Select the Application section of the page
  • Press the Copy button. This will copy the current application log to the system's clipboard.
  • Paste the log into an email or document to review it's contents.
Saving your configuration
  • Launch the RaceCapture app
  • Connect your RaceCapture system to the app
  • Navigate to Setup view.
  • Press the Read button to read the current configuration
  • Press the Save button to save the current configuration to the file you specify.
Recovering from a failed firmware update
If the firmware failed to update for some reason (e.g. the process was interrupted) RaceCapture will detect this upon power up and go right into bootloader mode, where it is ready to accept firmware again. This is indicated by a rapidly flashing LED on the device, with no other activity, and the inability to connect normally from the app.
Flashing firmware when already bootloader mode
  • Connect the device to your computer via USB
  • Go to Setup
  • Open a previously saved configuration file
  • Go to Firmware
  • Update the firmware as normal, bypassing any warning messages.
Note: - ensure you are flashing the firmware that matches your specific hardware version.
Factory Reset for RaceCapture
From Setup / Firmware
The easiest way to reset to factory defaults is to access the Firmware update view.
  • Connect your RaceCapture system via any supported connection
  • Go to Setup / Firmware.
  • Press the Factory Reset button.
Command line console
  • Close any running RaceCapture app
  • Launch a serial terminal program such as RealTerm or HyperTerminal (Windows), Minicom (Linux or OSX), and connect to the serial port assigned to RaceCapture.
  • Press Return on keyboard to see a list of commands.
  • Issue the command 'resetConfig'
  • Your RaceCapture system will be restored to a factory default configuration.
Flashing an older firmware
  • Flash a previous firmware that changes the major or minor version (major.minor.bugfix). This triggers an automatic factory reset.
    • Example: If you are on 2.13.5, flash 2.12.0.
  • Then, you can re-flash the original firmware.
  • Determine the location of the datastore file
To find it's location, launch the RaceCapture app and immediately go to the System Status view and press the Copy button to copy the application log file to the system's clipboard. RaceCapture application log.png
Example:
[Base        ] Start application main loop
[UserPrefs   ] Saving preferences
[Main        ] Datastore Path:/home/susy/.config/racecapture/datastore.sq3
[Main        ] initializing datastore...
[RacecaptureApp] initializing rc comms with, conn type: Serial
[RCPAPI      ] msg_rx_worker starting
[RCPAPI      ] cmd_sequence_worker starting
[RCPAPI      ] auto_detect_worker starting
  • Backing up and removing the current datastore.sq3
  • Re-launching the RaceCapture app
Hardware troubleshooting
RaceCapture/Pro
Stuck in bootloader mode
If your RaceCapture/Pro seems to be stuck in bootloader mode (rapidly orange flashing light (MK3) and app cannot connect), you may have a stuck button on the front panel. Normally the bootloader is activated while holding down the front button while powering up, but if the button is stuck, the unit will go into bootloader mode unexpectedly. Check if the button has been pushed down excessively on an edge; use a fingernail or tool to pull the edge up.
  • Note: When you press the button, you should feel a click when the switch engages.
Diagnosing Analog Inputs
Steps to verify the proper operation of analog inputs for RaceCapture:
  • Perform a factory reset by navigating to Setup / Firmware and pressing "Factory Reset" while connected to RaceCapture.
    • This will reset the system to factory defaults. Ensure your settings are saved so they can be later restored.
  • Connect the system to 12v power.
  • For each analog input in question:
    • Disconnect any sensor connected to the analog input
    • Enable the Analog channel in question by selecting a sample rate 1Hz or higher.
    • Connect a jumper wire between the analog input and ground. On the RaceCapture dashboard verify the channel shows very close to 0v (within 0.1v)
    • Connect a jumper wire between the analog input and the 5v reference. On the RaceCapture dashboard verify the channel shows very close to 5v (within 0.1v)
  • Notes
  • It is important the system is connected to 12v power so you can observe the full 0-5v range of the sensor input. If only connected to USB power, the max voltage input will read 4.6-4.8v.
  • RaceCapture inputs are buffered with very high impedance to avoid affecting the signal they are reading, much like a test instrument. If left disconnected, they will float and show a reading between 0 and 5v.
WiFi
WiFi stops working, stuck in endless checking wifi status
If the RaceCapture log shows a continuous stream of 'checking wifi status', like this:
Checking WiFi Device...
[esp8266] OP mode: 0
...and WiFi connectivity seems to have stopped, you can perform this low level factory reset for the wifi module.
  • Back up your configuration
  • Completely disable WiFi under Setup / Wireless
  • Load the script below into the scripting window, ensuring you remove any existing script.
  • Write the script
  • Power cycle
  • Check the log for no more repeated "Checking WiFi Device"..
  • Perform a regular factory reset.
  • Check for proper WiFi functionality (check if it shows up as an Access Point).
port = 5
initSer(port,115200, 8, 0, 1)
function sendCrlf()
  writeCSer(port, 13)
  writeCSer(port, 10)
function sendRaw(val)
  for i=1, #val do
function sendAt(msg)
  sendRaw(msg)
  sendCrlf()
  sleep(1000)
function readRes(lines)
  for i=1, lines do
    print(readSer(port))
    println(readSer(port))
sleep(1000)
sendAt('ATE0')
readRes(2)
sendAt('AT')
readRes(2)
sendAt('AT+RESTORE')
readRes(10)
