RacecaptureApex hardware install
Mounting Orientation
!!mounting orientation pic
Alternative Mounting
- Example:
- Upside down
- Vertical / on edge
Main Connector
The main connector provides access to all power, sensor and communications for the RaceCapture/Apex system.
| Power | |
| Connection | Color |
| 12v | Red |
| Ground | Black |
| Voltage Reference | |
| Yellow | +5v reference |
| Analog Sensor Inputs | |
| White | Analog Input 1 |
| Gray | GPIO 1 |
| Auxiliary Serial Input | |
| CAN Bus | |
| Orange | CAN 1 Low |
Plug Connector Type
The standard Deutsch DTM connector system is used:
- DTM06-12SA
- DTM06-12SB
- Matching wedge lock (WM-12S)
- Pins 0462-201-20141
Cellular Telemetry
SIM card installation
RaceCapture/Apex requires a micro SIM from a GSM provider, such as AT&T, T-Mobile, FreedomPop, or many other worldwide providers.
Install the micro SIM in the card slot behind the rubber flap at the rear of the unit. The SIM fits in the bottom position of the card holder; the Micro SD installs in the top position.
- More Info:; See the Real-time telemetry guide for additional setup instructions
Antenna Placement Guide
Cellular antenna
Antenna separation
Powering
Connect RaceCapture/Apex to a 12v source, ideally switched with main power or via ignition power.
Power requirements
| Voltage | 12-24v |
| Fused circuit | 5A max |
Analog Sensor inputs
| Voltage Range | 0-5v |
Connecting Sensors
- See our comprehensive Sensor Guide for information on connecting various types of analog sensors.
You can connect RPM, wheel speed and other pulse-type sensors to RaceCapture/Apex frequency input pins.
| Voltage Range | 0-12v |
Signal input quality
Special note about RPM inputs
- If your only source for RPM is the trigger wire driving the ignition coil primary winding, then you will need the CoilX module to buffer / filter the noisy, high-voltage component.
Connecting Sensors
GPIO
RaceCapture/Apex provides 3 General Purpose Input Output (GPIO) ports which you can use to control devices (Output mode) or read switches or high / low states of electrical signals.
| Output mode type | Open Drain (connects ground when activated) |
| Input voltage protection | 0-40v - inductive protection up to 1A |
Input Mode
When configured for input mode, the RaceCapture/Apex sensor input will register a '1' when the input passes a voltage threshold of approximately 3v, and '0' when the input is low (close to 0 volts).
Important Note: when sensing large inductive loads, such as sensing brake light state or sensing the on/off state of a motor, connect a 10K 1/4 watt resistor in-line with the GPIO input to protect RaceCapture/Apex from a large inductive spike.
Output Mode
Output Behaviour
GPIO Connections
Controlling GPIO Ports
Communications
CAN Channels 1 / 2
| CAN channels | 2 |
| CAN bus compatibility | CAN 2.0 compatible, 1M baud |
Auxiliary Serial
One Auxiliary RS232 compatible serial port is available on the main connector. You can use this to communicate with external devices that uses RS232 serial for communications.
- See the Lua scripting guide and Examples
