ESP32-CAN-X2
Revision as of 15:43, 8 January 2025 by Brentp (talk | contribs) (→Introduction)
Buying
  • Reset and Boot push button
  • Integrated CAN transceivers
Bolt-ons
Bolt-ons are stackable add-on boards that offer easy extensibility:
GPS bolt-on
Adds a high performance GPS receiver
Button bolt-on
Adds 4 tactile switches + RGB LEDs
RGB LED bolt-on
Adds 10 RGB LEDs across two groups for alert indicators
Getting started
Figure 1
Microcontroller
Figure 2
External Connection Header
CAN Controllers
Figure 3
Two 4-Pin header Connector
Built-in LED
USB-C Socket
Debug Connector
The following 6-pin connector marked as X4 is used for serial communication and debugging purposes with ESP32 CAN X2. The 6-pin configurations on the ESP32 CAN X2 is arranged as follows:
Figure 4
Board Layout
  • Width  : 42.10 mm
  • Length : 72 mm
Power Options
Pin Voltage
VIN Rating
Operating Current
Power Consumption
Operating Temperature
CAN bus information
Multimaster system
Lossless communication
Simple and cheap
Errorless communication
CAN network types
Data transmission
Note : The low-speed CAN, single wire CAN, may not require the CAN bus termination.
Board Pinout
Figure 7
Pin Function Description
5 RX Pin USART RX
6 TX Pin USART TX
16-18 GND Ground
12v note
Top Headers Pinout
Figure 8
1 +12V_AUX 6-12V Power Supply
4 GND Ground
4 GND Ground
Flashing Firmware
Hardware Components
  • USB-C cable
Software Components
Note : Link to download Arduino IDE : https://www.arduino.cc/en/software || Link to download Mu Editor : codewith.mu
Sample Arduino Project
  • Open Arduino Ide
  • Go to File > Preferences
Figure 7
Json URL : https://espressif.github.io/arduino-esp32/package_esp32_index.json
Figure 8
Figure 9
Figure 10
Flashing
Figure 11
Figure 12
Sample CircuitPython code
Installing ESP-32-X2 is simple, please follow the steps given below :
Click on the browse S3
  • Select the desired language
Flash the Firmware
written.
Exit Bootloader Mode
Importing libraries in Circuitpython is straightforward. For installing Libraries in Circuitpython, please follow the steps given below :
  • Extract the zip file.
ESP32-CAN-X2 Rev-C
ESP32-CAN-X2 Rev-C
