RaceCaptureTrack MK4
Quick Start Guide
Connecting the Hardware
Mounting
To ensure optimal performance, mount the RaceCapture system on a flat, level surface within the vehicle, with the connectors oriented toward the front. This orientation aligns with the factory calibration of the internal accelerometer and gyroscope.
- Mount the unit in a concealed, protected area of the vehicle, away from direct heat sources and moisture.
- Use hook-and-loop (Velcro) fasteners or other suitable mounting methods to secure the unit in place while allowing for easy removal if needed.
Note: If it is necessary to install the unit in an alternative orientation (e.g., vertical, on-edge, or upside down), ensure it is rotated in clean 90-degree increments relative to the vehicle’s primary axes. Avoid mounting the device at an arbitrary angle, as this can affect sensor accuracy. For non-standard orientations, remap the accelerometer and gyroscope axes in the Setup menu to reflect the installed position.
Connectors
- M8 6-Pin Female Connector (CAN1 / CAN2 / Power)
- M8 4-Pin Female Connector (CAN1 / Power)
- SMA Antenna Connector (L5_GNSS, LTE)
Positioning the Antenna
- Mount the antenna on the roof of the vehicle using the supplied magnetic base.
- Maintain a minimum separation of 3 feet (1 meter) from other transmitting antennas (e.g., cellular, FM/AM radio) to reduce signal interference.
- You can also place it on the dashboard, with an unobstructed view of the sky or on the rear parcel shelf, under the back window.
Powering up the Module
USB Power (USB Type-C)
- A computer USB port
- A USB car charger
- A USB battery pack
Windows / MacOS / Linux
- Get the latest version of the RaceCapture app from the Downloads Page.
- Start the RaceCapture app.
Android / iOS
On Raspberry Pi
- After powering up RaceCapture/Track MK4 with 12v or via USB power (computer or USB power source) and Installing the Race Capture App.
- Go to your device’s WiFi settings and connect to the RaceCapture/Track MK4 WiFi access point.
- Note: The default WiFi access point is open (no password). You can configure a password and enable encryption later under Setup > Wireless in the RaceCapture app.
- On Android devices, you can also pair via Bluetooth using the default PIN 1234. This can also be changed later in Setup > Wireless.
- Once you've linked the Bluetooth or WiFi (Mobile), or USB (Windows or OSX) launch the RaceCapture app.
- Launch the RaceCapture app to begin configuration. The app will automatically start the First-Time Setup Wizard to guide you through the initial setup process.
First Time Wizard Setup
The RaceCapture app will guide you through a brief automated setup and tour. During this process the connection to RaceCapture/Track MK4 will be verified.
Configure System Presets
Select Favorite Race Tracks
- Select the tracks you will typically race at so RaceCapture can auto detect the track location and calculate lap times.
- Note: Only select the one-track configuration per race track, to ensure the correct track is auto-selected.
- If you don't see your track listed, Please Submit Your Track!
LED Status Indicators
| LED | Function |
| CAN | Indicates activity on the OBD-II / CAN bus network. Blinks when data is being received from the ECU or sensors. |
| GPS | Indicates GPS status: Slow flash: Searching for satellite lock |
| Error | Illuminates when the system encounters an error. Check the RaceCapture app logs for details. |
| Power | Illuminates when the unit is powered via 12V or USB. |
| Telemetry indicator | Indicates when real-time telemetry is actively broadcasting |
Comprehensive Setup Guide
Data System Cable Connection
| Pin | Connection | Notes |
| 1 | CAN low | White |
| 3 | CAN high | Green |
| 4 | Ground | Black |
| 1 | CAN 1 Low | |
| 2 | CAN 2 Low | |
| 3 | CAN 2 High | |
| 4 | Ground | |
| 5 | CAN 1 High | |
| 6 | Power | 9–24V / 1A (~12W) |
M8 CAN Bus to OBD-II cable
Connection Steps
- Plug the M8 connector end of the cable into the CAN port on the RaceCapture/Track MK4.
- Connect the OBD-II connector end to the vehicle’s OBD-II diagnostic port (typically located under the dashboard).
- Ensure the connection is secure before powering on the system.
Vehicle compatibility
CAN Channel Mappings
- View currently active channels
- Modify channel parameters (e.g., CAN ID, offset, formulae)
- Remove unused or duplicate channels
- Add custom channels manually if needed
- For Custom Modification you can refer to Lua Scripting Guide for detailed instructions and examples.
CAN Bus Configuration
- Ensure that termination is enabled if RaceCapture/Track MK4 is at one end of the CAN bus.
Driver ID
Heart Rate Monitoring
Setup Instructions
- Ensure your RaceCapture/Track MK4 system is upgraded to the latest firmware and the latest version of the RaceCapture app is installed.
To Verify:
Racecapture
Podium
Telemetry and Logging Setup
Enabling WiFi Telemetry
On Board Flash Memory Logging
To enable USB drive mode:
Important Caveats:
Formatting Flash Memory:
Firmware and Software Updates
Backing Up Configurations
- Connect to RaceCapture/Track MK4 using the RaceCapture app - using USB, or WiFi.
Updating Firmware
- Download the latest RaceCapture firmware from Firmware
- Press Open
Restoring Settings
