RaceCaptureTrack MK4
Quick Start Guide
Connecting the Hardware
Mounting
To ensure optimal performance, mount the RaceCapture system on a flat, level surface within the vehicle, with the connectors oriented toward the front. This orientation aligns with the factory calibration of the internal accelerometer and gyroscope.
Note: If it is necessary to install the unit in an alternative orientation (e.g., vertical, on-edge, or upside down), ensure it is rotated in clean 90-degree increments relative to the vehicle’s primary axes. Avoid mounting the device at an arbitrary angle, as this can affect sensor accuracy. For non-standard orientations, remap the accelerometer and gyroscope axes in the Setup menu to reflect the installed position.
Connectors
  • SMA Antenna Connector (L5_GNSS, LTE)
Positioning the Antenna
Powering up the Module
USB Power (USB Type-C)
  • A computer USB port
  • A USB car charger
  • A USB battery pack
Windows / MacOS / Linux
  • Connect your Podium Connect Micro to your computer with the USB cable,
  • Start the RaceCapture app.
Android / iOS
On Raspberry Pi
  • On Android devices, you can also pair via Bluetooth using the default PIN 1234. This can also be changed later in Setup > Wireless.
First Time Wizard Setup
The RaceCapture app will guide you through a brief automated setup and tour. During this process the connection to RaceCapture/Track MK4 will be verified.
Configure System Presets
Select Favorite Race Tracks
Wi-Fi Operating Modes and Reliability Improvements (Firmware v2.23.3)
Access Point (AP) Mode
When operating in this mode:
Wi-Fi Reliability Improvements in Firmware v2.23.3
Firmware version 2.23.3 introduces multiple improvements to Wi-Fi reliability and connection stability for RaceCapture/Track MK4 and PodiumConnect/Micro. These updates are focused on improving real-world Wi-Fi behavior during configuration and telemetry use.
Summary of Improvements
  • Improved Wi-Fi connection stability during normal operation
  • More reliable reconnection behavior after temporary signal loss
  • Improved handling of access point and network transitions
  • Reduced likelihood of stalled or unresponsive Wi-Fi connections
  • Improved behavior during STA hotspot scanning
  • General robustness improvements when operating in environments with variable or congested wireless conditions
LED Status Indicators
LED Function
GPS Indicates GPS status:
Telemetry indicator Indicates when real-time telemetry is actively broadcasting
Comprehensive Setup Guide
Data System Cable Connection
Pin Connection Notes
1 CAN low White
3 CAN high Green
4 Ground Black
1 CAN 1 Low
2 CAN 2 Low
3 CAN 2 High
4 Ground
5 CAN 1 High
6 Power 9–24V / 1A (~12W)
M8 CAN Bus to OBD-II cable
Connection Steps
  1. Plug the M8 connector end of the cable into the CAN port on the RaceCapture/Track MK4.
  2. Connect the OBD-II connector end to the vehicle’s OBD-II diagnostic port (typically located under the dashboard).
  3. Ensure the connection is secure before powering on the system.
Vehicle compatibility
CAN Channel Mappings
CAN Bus Configuration
System Overview
Supported Features
  • RaceCapture/Track MK4 support upto 16 TPMS sensors
    • Left Front
    • Right Front
    • Left Rear
    • Right Rear
Registering TPMS Sensors
  2. Select TPMS
  3. Select Register Sensor.
Sensor Identification Notes
640PX
Driver ID
Heart Rate Monitoring
Setup Instructions
To Verify:
Bluetooth Connectivity
Default Bluetooth Password
Connecting via Bluetooth
  • Power on the RaceCapture/Track MK4
Changing Connection Type
  • Open the RaceCapture app.
Racecapture
Podium
Telemetry and Logging Setup
On Board Flash Memory Logging
To enable USB drive mode:
Important Caveats:
Formatting Flash Memory:
Firmware and Software Updates
Backing Up Configurations
  • Connect to RaceCapture/Track MK4 using the RaceCapture app - using USB, or WiFi.
Updating Firmware
  • Download the latest RaceCapture firmware from Firmware
  • Connect RaceCaptureTrack MK4 via USB (Windows or OSX only)
  • Navigate to the RaceCaptureTrack MK4 firmware you unzipped. The file will end with the extension '.ihex'. Example: PodiumConnect_2.15.2.ihex
  • Press Open
Restoring Settings
