RaceCaptureTrack MK4
Revision as of 04:28, 14 April 2026 by Brentp (talk | contribs) (→Connecting to RaceCapture System Dashboard)
Quick Start Guide
Connecting the Hardware
Mounting
This orientation aligns with the factory calibration of the internal accelerometer and gyroscope.
Additional Notes:
Connectors
  • SMA Antenna Connector (L5_GNSS, LTE)
Positioning the Antenna
Powering up the Module
USB Power (USB Type-C)
  • A computer USB port
  • A USB car charger
  • A USB battery pack
Windows / MacOS / Linux
  • Connect your RaceCapture to your computer with the USB cable,
  • Start the RaceCapture app.
Android / iOS
On Raspberry Pi
  • On Android devices, you can also pair via Bluetooth using the default PIN 123456. This can also be changed later in Setup > Wireless.
First Time Wizard Setup
The RaceCapture app will guide you through a brief automated setup and tour. During this process the connection to RaceCapture/Track MK4 will be verified.
Configure System Presets
Select Favorite Race Tracks
Wi-Fi Operating Modes
Access Point (AP) Mode
When operating in this mode:
LED Status Indicators
LED Function
GPS Indicates GPS status:
Telemetry indicator Indicates when real-time telemetry is actively broadcasting
Real-time Telemetry Setup
Step 1 : Configure WiFi Connectivity
  • Select the Wireless tab.
      • Enable WiFi Support
      • Enable Client Mode
Step 2 : Configure the Telemetry Streaming Key
  • Open the Podium website.
Step 3 : Configure Streaming Behavior
Step 4: Apply Configuration and Reboot
Reboot the device by either:
  • Power cycling the unit, or
Step 5 : Verify WiFi Connection
After rebooting:
Step 6 : Confirm Telemetry Streaming
  • The blue telemetry LED on the device will blink.
Viewing Live Telemetry
Podium Website
  • Navigate to Events.
    • IMU motion
    • G-forces
    • Sensor values
Podium App
  1. Open the Podium app.
  3. Select your device.
From here you can:
  • View live dashboards
  • Switch dashboard views
Dashboards can be:
  • Custom created and saved
  • Shared by the community
Track Detection and Lap Timing
  1. Navigate to Racetracks.
  • Lap timing
Comprehensive Setup Guide
Data System Cable Connection
Pin Connection Notes
1 CAN low White
3 CAN high Green
4 Ground Black
1 CAN 1 Low
2 CAN 2 Low
3 CAN 2 High
4 Ground
5 CAN 1 High
6 Power 9–24V / 1A (~12W)
M8 CAN Bus to OBD-II cable
Connection Steps
  1. Plug the M8 connector end of the cable into the CAN port on the RaceCapture/Track MK4.
  2. Connect the OBD-II connector end to the vehicle’s OBD-II diagnostic port (typically located under the dashboard).
  3. Ensure the connection is secure before powering on the system.
Vehicle compatibility
CAN Channel Mappings
CAN Bus Configuration
System Overview
Supported Features
  • RaceCapture/Track MK4 support upto 16 TPMS sensors
    • Left Front
    • Right Front
    • Left Rear
    • Right Rear
Registering TPMS Sensors
  2. Select TPMS
  3. Select Register Sensor.
Sensor Identification Notes
640PX
Driver ID
Heart Rate Monitoring
Setup Instructions
To Verify:
Bluetooth Connectivity
Default Bluetooth Password
Connecting via Bluetooth
  • Power on the RaceCapture/Track MK4
Changing Connection Type
  • Open the RaceCapture app.
Racecapture
Podium
Telemetry and Logging Setup
On Board Flash Memory Logging
To enable USB drive mode:
Important Caveats:
Formatting Flash Memory:
Firmware and Software Updates
Backing Up Configurations
  • Connect to RaceCapture/Track MK4 using the RaceCapture app - using USB, or WiFi.
  • Navigate to Setup and press the Read button to read the current settings from your system.
Updating Firmware
  • Download the latest RaceCapture firmware from Firmware
  • Connect RaceCaptureTrack MK4 via USB (Windows or OSX only)
  • Navigate to the RaceCaptureTrack MK4 firmware you unzipped. The file will end with the extension '.ihex'. Example: PodiumConnect_2.15.2.ihex
  • Press Open
Restoring Settings
Mounting and dimensions
STEP file for mounting pattern
Download : File:RCT-Mk4 enclosure solid for mounting pattern.zip
Dimensions
