CAN Bus Integration
Prerequisites
- Basic understanding of math
- Basic understanding of data represented as bits and bytes
- Basic knowledge of CAN bus technology. Here are some some helpful links.
Preset configurations
Wiring CAN bus
Molex connector
- Applies to
- RaceCapture/Pro MK3
RJ45 connector
- Applies to
- RaceCapture/Pro MK2
Cabling
| +12v | Brown |
| Ground | Orange/White |
| CAN 1 High | Orange |
| CAN 1 Low | Green/White |
- Important note for MK2: The +12v connection on the RJ45 is connected internally to the +12v on the terminal block on RaceCapture/Pro MK2. It's recommended you only power via one source - RJ45 or terminal block - if you have both connected at the same time, you may cause back-feeding of power through RaceCapture/Pro, which may cause damage to the unit. Note: RaceCapture/Pro MK3 has internal protection diodes which avoids this issue.
Researching CAN Bus protocol
CAN Bus documentation
- Channel: (RPM, Engine Temperature, Throttle Position, etc)
- CAN Identifier: The CAN Identifier for each channel. This may appear in either 11 or the extended 29 bit format. Typically 11 bits are used.
- Offset: where the data starts within the 8 byte CAN message. An offset of 0 means the data starts on the first byte.
- Length: Typically 1 or two bytes
- Scaling: The raw value from the message is often scaled to a real world value. Typically this is provided as a multiplier and adder value.
Big Endian or Little Endian mode
Additionally, the manufacturer will specify if multi-byte (16, 24 or 32 bit) values are presented in Big Endian' (MSB (Most Significant Bit)) or Little Endian (LSB (Least Significant Bit)) mode.
- Decimal value: 1000
- Hex Value in Big Endian: 0x03E8
- Hex Value in Little Endian: 0xE803
MSB format:
- Offset 1
- Length 2
- Data:
(Hex) [xx] [03] [E8] [xx] [xx] [xx] [xx] [xx] (Decimal) [xx] [3] [232] [xx] [xx] [xx] [xx] [xx]
LSB format:
- Offset 1
- Length 2
- Data:
(Hex) [xx] [E8] [03] [xx] [xx] [xx] [xx] [xx] (Decimal) [xx] [232] [3] [xx] [xx] [xx] [xx] [xx]
Enabling CAN bus
Mapping CAN data to channels
Direct CAN mapping
Adding a channel
- To start, connect to your RaceCapture device and ensure the current configuration is read, or open a previously saved configuration.
- Navigate to the CAN Mapping page.
- Ensure CAN channels is set to on
- Press the (+) button to add your first channel.
Defining the Channel
- Channel Name: selecting a channel name from the drop-down will pre-set the units, min and max to typical values. You can customize this by pressing the gear icon.
- Rate: This sets the rate that RaceCapture will log or broadcast the data for this channel. This rate is independent of the actual rate the CAN data is received.
Defining the CAN ID and bus
- CAN ID: this is the ID of the CAN bus message
- Mask: This is an optional mask - if set to greater than zero, the Mask will be logically AND'd with the CAN ID for further matching and filtering.
- If uncertain, leave this unchanged
- CAN Bus: Select the CAN bus your data is appearing on - CAN 1 or 2, depending on the available CAN ports of your RaceCapture device.
Defining the mapping
- Offset: this is the offset where the data appears in the CAN message. An offset of 0 would be used to start at the first byte of the CAN message.
- Length: this represents the length of the value. A length of 1 would be one byte, 2 would represent a two byte or 16 bit word, and so on.
- Source Type: this represents the native encoding of the data. Most typically this is represented as a plain unsigned value, but can appear in other formats. The manufacturer's CAN documentation will identify the data type. Supported native data types:
- Unsigned: The data is provided as an unsigned value.
- Signed: The data is provided as a two's compliment signed value.
- Float: The data is provided as a IEEE-754 encoded floating point value
- Sign-Magnitude: The data is provided as a sign-magnitude encoded value.
- Endian: This defines Big Endian (Most significant bit / MSB) or Little Endian (Least Significant Bit / LSB) mode, and applies to values where the data length is 2 or higher. The manufacturer's documentation will identify whether the data is encoded in big or little endian format.
- Bit Mode: This allows mapping in cases where the data does not fall on even byte boundaries. For example, you may want to extract a single bit at the offset of 11; in which case you would enable bit mode, then set your offset to 11 with a length of 1.
- If uncertain, leave this unchecked, or check the manufacturer's documentation
Defining the Formula
Units Conversion
You can optionally apply a common units conversion to the value after it has been processed by the formula. Often the manufacturer will provide the mapping in one form of units - this allows you to retain the original mapping and then convert the units to the desired format. You can, of course, apply no units conversion.
Testing your channel
Not getting the expected data?
See the Troubleshooting Guide to help understand and identify problems in your CAN mapping.
Lua scripting
- Applies to:
- RaceCapture/Pro
- RaceCapture/Apex
Reading a CAN message
id, ext, data = rxCAN(0, 100)
Mapping to a Virtual Channel
- Set up the channel. Example "EngineTemp"
- Read a CAN message
- Extract a value from the data fields
- Scale the extracted value to a real world value (Example: Degrees F)
- Set the virtual channel with the scaled value
- Example: Set MyChannel from CAN ID 1234. Data is in the first byte of the message.
id, ext, data = rxCAN(0)
if id == 1234 then
CAN integration framework
tickRate = 30
--the CAN baud rate
CAN_baud = 500000
CAN_chan = 0
be_mode = 0
CAN_map = {
processCAN(CAN_chan)
function processCAN(chan)
repeat
local map = CAN_map[id]
if map ~= nil then
map(data)
until id == nil
offset = offset + 1
local value = 0
local shift = 1
while len > 0 do
shift = shift * 256
offset = offset + 1
len = len - 1
offset = offset + 1
local value = 0
while len > 0 do
offset = offset + 1
len = len - 1
initCAN(CAN_chan, CAN_baud)
Reverse Engineering
Common Approach
- Log all messages from the CAN bus
- Directly measure or observe a sensor channel and compare it against changes in the CAN bus data, watching for patterns.
Example
Logging Data
Check the CAN bus settings
- Ensure the root CAN configuration is turned on at the high level settings
- Ensure the baud rate is set correctly for the CAN network you are connected to
- Ensure the CAN termination is correct for the network you are on.
- Note: RaceCapture/Pro and RaceCapture/Apex have CAN termination enabled by default
Check the CAN activity LED
- The CAN activity LED will indicate if CAN data is being received by your RaceCapture system.
CAN bus logger
- Try using the simple logging script to verify the incoming data is what you expect, and compare that against the manufacturer's specifications.
