PodiumConnect
Getting Started
Installing the app
Android / iOS
Running and Connection
- Start the RaceCapture app.
Android / iOS
First time setup wizard
Select your favorite Tracks
Create an account on Podium / Setting Device ID
Select your cell provider
Freedom Pop
Further Setup
Connecting your Data System
Testing Telemetry
Install your SIM card
Verifying
Installing the unit
Using Podium
