RacecapturePro MK3 hardware install
Revision as of 22:09, 26 July 2019 by Sbarton (talk | contribs) (→‎GPIO)
Mounting Orientation
Alternative Mounting
  • Example:
    • Upside down
    • Vertical / on edge
Mounting Dimensions
(Click to zoom)
Main Connector
Power
Connection Color
12v Red
Ground Black
Frequency / RPM sensor inputs
Blue Frequency / RPM input 1
Voltage Reference
Yellow +5v reference
Analog Sensor Inputs
White Analog Input 1
Gray GPIO 1
Gray / White Stripe GPIO 2
Gray / Blue Stripe GPIO 3
Auxiliary Serial Input
CAN Bus
Orange CAN 1 Low
Plug Connector Type
Other connector sources
Cellular Telemetry
Antenna Placement Guide
Cellular antenna
Antenna separation
It's recommended you separate the GPS and cellular antennas as reasonably far apart as possible, such as mounting at opposite ends of the roof. RaceCapture Pro MK3 antenna install.png
RJ45 CAN + Power connection
OBDII CAN cable
Custom Cable
+12v Brown
Ground Orange/White
CAN 1 High Orange
CAN 1 Low Green/White
CAN 2 High Blue
CAN 2 Low Blue/White
Powering
Power requirements
Power requirements
Voltage 12-24v
Fused circuit 5A max
Powering Notes
  • You can also power via the RJ45 connector, useful when plugging in to OBDII.
  • Power can not be passed between RJ45 and the main connector, to prevent backfeeding of circuits in the vehicle.
Analog Sensor inputs
Analog channel specifications
Voltage Range 0-5v
ADC precision 12 bit SAR
Connecting Sensors
Voltage Range 0-12v
Signal input quality
Special note about RPM inputs
Connecting Sensors
GPIO
GPIO channel specifications
Input Mode
Output Mode
When configured for output mode, RaceCapture can sink a 1A load per port, suitable for driving indicators, relays, sending signals to other systems and driving small devices.
Output Behaviour
GPIO Connections
Controlling GPIO Ports
Communications
CAN Channels 1 / 2
CAN channel specifications
CAN channels 2
CAN Filters 14 per channel
Auxiliary Serial
