RaceCapture App User's Guide
Install the RaceCapture app
On Desktop
USB Drivers
On Raspberry Pi
Setup Wizard
When you run RaceCapture for the first time, you are presented with a first time setup wizard. Follow this guide to set up your device.
- Note: You can access first time setup again by navigating to the main Setup page.
Importing a new dashboard
You can add additional dashboard pages by browsing a list of system-provided dashboard templates, or import dashboards designed by other racers like you.
To edit a gauge:
- Unlock the dashboard
- Display channel
- Color
- Min/Max range
Dashboard Alerts
Use the central alerts editor:
- Go into dashboard settings by pressing the gear icon
Edit alerts from a gauge:
- Edit a gauge
Customizing your dashboard
Saving your dashboard
Predictive Lap timing
Analysis
- Note: The system default is to trigger on Speed
Cursor across line chart
Playback Control
- Zooming For line charts, you can zoom on the data using a two-finger pinch gesture, or using the mouse scroll wheel or your laptop's trackpad scroll gesture.
Selecting time vs distance
Android
iOS
System Setup
Explanation of buttons
Pulse/RPM sensors
Digital In/Out
CAN bus mapping
Automatic Control
Scripting
Diagnostic Logs
Firmware
Extra Information
