RaceCapture App User's Guide
About the guide
Compatible OS
How to Install
How to Update
Icons Used in Manual
The information contained in this document is the intellectual property of Autosport Labs, and No one use it without the prior permission of Autosport Labs
Help
Any quire, concern or issue regarding the app may be resolved by contacting the Autosport Labs support team our support team by phone or direct email
- @autosportlabs.com "
Install the RaceCapture app
On Desktop
USB Drivers
On Raspberry Pi
Setup Wizard
When you run RaceCapture for the first time, you are presented with a first time setup wizard. Follow this guide to set up your device.
- Note: You can access first time setup again by navigating to the main Setup page.
Importing a new dashboard
You can add additional dashboard pages by browsing a list of system-provided dashboard templates, or import dashboards designed by other racers like you.
To edit a gauge:
- Unlock the dashboard
- Display channel
- Color
- Min/Max range
Dashboard Alerts
Use the central alerts editor:
- Go into dashboard settings by pressing the gear icon
Edit alerts from a gauge:
- Edit a gauge
Customizing your dashboard
Saving your dashboard
Predictive Lap timing
Analysis
- Note: The system default is to trigger on Speed
Cursor across line chart
Playback Control
- Zooming For line charts, you can zoom on the data using a two-finger pinch gesture, or using the mouse scroll wheel or your laptop's trackpad scroll gesture.
Selecting time vs distance
Android
iOS
System Setup
Explanation of buttons
Pulse/RPM sensors
Digital In/Out
CAN bus mapping
Automatic Control
Scripting
Diagnostic Logs
Firmware
Steps to recover:
- Connect RaceCapture via USB
Extra Information
